Question about Kodak EasyShare C1013 Digital Camera
The sd memory card : i can't push it when i did it didn't work but suddenly it pop up
The sd memory card dosen't enter ..it was entering since i bought the camera but these days i think it felt down and after that the memory card didn't enter..help
    Top Expert:
  • Kodak Master
  • 6,702 Answers
Did you try to put in another card already?
Just to establish if the defect is in the camera or in your card. When you push in the card a little pal will lock the card in the camera. If the card lost a little of its outside, it could be the lock is not ok. I'm afraid something is wrong with the pal in the camera. But you need a good set of eyes, some knowledge how the card locks in and a peek into the card holder, to see if it works correct.
Posted on Dec 26, 2013
brucecolter
SOURCE: SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Posted on May 04, 2012
Tri3mast
  • 747 Answers
SOURCE: The camera keeps saying "Memory
It's not the camera. I hope you have the original card if not no matter. I'm including a diagram that shows a locking switch on an SD card the black arrow points to the little switch in the unlock position. Now something else you will need to format the memory card to make it compatible to your camera. This function is in "set up" and you need to use the arrow keys to navigate to that function. Format the card and everyone will be happy again. Another thing each time you download pictures to your computer you need to format the memory card. What I expect you are doing or have been doing is deleting the pictures. This works but eventually it leaves the card full of holes and dirty and the camera can no longer write to it. I full expect that if you still have the original SD car that you can format it as well and it will work again. Now saying that because it's so dirty (with old deleted information not actual dirt) you may need to format that card a few times (maybe twice). This will solve your problem
Diagram
Posted on Jan 07, 2011
mads_aye
  • 58 Answers
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
Posted on Feb 13, 2008
SOURCE: cards not working with camera
i had a similair problem with my memory card and kodak camera.
I solved it by formatting the card in a camcorder that takes sd cards.
hope this helps
Posted on Oct 12, 2008
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
Posted on Dec 05, 2008
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
I have been using my PNY OPTIMA HC 4gb memory card to upload pics for months and all of a sudden it will not read or allow me to upload
Solution overview: You need to "clean" theSD card by using the clean command in Diskpart and then format the card in DiskManagement. This solution will show you how to accomplish this.
1. Plug the SD Card into the computer.
2. Press Win+R to open the Run command.
3. Type "cmd" into the dialog box and press enter to open acommand prompt.
4. Type "Diskpart" into the command line of the command promptto start Diskpart. Wait for Diskpart to load.
5. Type "List Disk" and press enter.
6. Take note of the number of the disk that's associated with your SD card.
7. Type "Select Disk X" where X = the number of the diskthat's associated with your SD card and press enter. Make sure the commandprompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and pressenter. Clean will be faster but might not solve your problem. If using theclean command doesn't solve your problem, then repeat steps 1-8 and type "Cleanall".
9. Wait for Diskpart to complete the cleaning operation - this may take sometime so wait until it's completed!
10. Close command prompt.
11. Press Win+R to open the Run command.
12. Type "DISKMGMT.MSC" into the dialog box and press enter.Wait for Disk Manager to load.
13. In Disk Manager, scroll down and select the SD Card.
14. Right click and select "New Simple Volume".
15. Select Next, Assign Drive Letter, and select "Next" again.
16. Select "FAT32" for File System and "Default"for Allocation Unit Size. Fill in whatever you want for the Volume Label. Makesure "Perform quick format" is checked and click OK.
17. Wait for formatting to complete and remove SD card from computer.
18. Plug SD card into camera to see if the problem is solved.
Good luck and thanks for using FixYa. Post back if you have any questions orproblems.
Mar 15, 2011 | PNY 4GB Secure Digital High Capacity...
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
2. Press the MODE button twice to enter Playback mode. Then press
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
How do i go about formatting my kingston sd card, step-by-step?
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Nov 28, 2009 | Kingston 4GB Secure Digital High Capacity...
Problem with the sandisk 4gb micro sd card. my computer cant format it. Y
some comp cant read the card a cheap fix is go to radio shack and get a reader/writer card its a usb connnection and should work for it did for me even my printer couldn t read my 4 gb
Aug 10, 2009 | SanDisk 4GB microSD High Capacity Memory...
Cant Find Files from SD Card for my Palm Treo 750
-Try the card reader in a different computer
Also, Try this:
1. Click start
2. Click "Run"
3. Type CMD
4. Hit Enter
5. At the new screen (command line interface), type "CD\" (no quotes) and press enter
6. Type the letter of the drive your SD card is located and then add a colon (example F:), hit enter
7. Type "dir /s > files.txt", hit enter
8. If it works you'll just see a new line
9. Browse to the root directory of your SD card and see if "Files.txt" is there (this should contain all files on your card)
Additionally try a search like this:
(if u can't see pic, click here
Let me know if that is reading your files... if it is... we have a chance to save them
Jan 06, 2008 | Computers & Internet
How to unlock UMAX 512 MB SD card
Try safely ejecting the card, it actually has a small switch on it, which depending on where its pushed will lock or unlock..look closely.
Oct 20, 2007 | Generic Memory PCI USB and Firewire Combo...
Kodak EasyShare C1013 Digital Camera Logo
20 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
