Question about Cutter Tools
Is it worth me buying a pipe cutter or is it not something i'll ever get round to using?
  • 67 Answers
If you are cutting copper pipe yes they are fairly cheap and do a much better job of cutting the pipe making it easier to insert into fluxed fittings for soldering
Posted on Dec 26, 2014
    Problem Solver:
  • 9 Answers
If you plan to do any kind of plumbing work in your house i would strongly recommend that you invest in a pipe cutter. They give a much neater and easier finish than a saw but if you don't do much DIY and are more likely to call in a plumber than to do it yourself, don't bother spending the money.
Posted on Dec 26, 2013
Auto retract slice cutter slider that moves blade out will not latch. I have to hold it in place with my thumb and so can't make any cuts. Am I missing something?
If I am reading this correctly, your answer may be that the cutter is designed that way for safety. "Auto-retracting". You find it in some utility knives that often store employees are required to carry so they won't "hurt themselves". Annoying, really. Try buying another cutter that is not an "auto retract"-- or get used to using your thumb for the purpose of holding the slide so the blade stays exposed.
Mar 23, 2014 | Slice Ceramic Safety Cutter
Tip
How to Use a Pipe Cutter? Pipe cutters are really useful tools that can...
Pipe cutters are really useful tools that can be used in the house to cut pipes that are made from metal or plastic. You could always try using a saw of some kind but pipe cutters will give you a much straighter edge.
Here are some basic instructions to help you successfully use a pipe cutter.
1. Decide exactly where on the pipe you would like to make a cut.
2. Loosen the handle on the pipe cutter and place it around the pipe.
3. Now tighten the cutter until the blade is in contact with the pipe.
4. Turn the pipe cutter a few turns around the pipe and it will score a line into the pipe.
5. Keep turning the pipe cutter around until you've cut the pipe off.
6. In order to create a nice straight edge inside the cut pipe you need to take the bottom blade out of the pipe cutter.
7. Place it into the cut end of the pipe and turn it around a few times until it's nice and smooth.
on Nov 21, 2013 | Cutter Tools
What is a pipe cutter? What can I use it for?
A pipe cutter is a tool that plumbers use to cut pipes. It gives a much cleaner and better cut than saws.
Dec 26, 2013 | Cutter Tools
Should i use my pipe cutters on very thin or small metal piping?
no, it will probably be easier and better overall to use a sharp pair of pruning shears. if you dont have any good shears, you can use pipecutters
Jan 16, 2013 | Cutter Tools
I need to know how to fix my brake line for a 1999 buik lesabre limited edition
I recommend getting a Haynes manual to follow when doing this repair (if you are going to do it on your own). These manuals have pictures, and very thorough instructions for repairs such as this, along with safety guidelines to make sure you are doing it properly. It will help you avoid mistakes and keep you safe on the road. I'll include a brief description of how to fix a break line, but I will probably forget to write something here, ad I don't want you to get hurt because I forgot to put in some piece of information -- so please buy the manual to make sure I have given you good information.
1. You'll need a pipe-cutter, a pipe bending tool and a pipe-flanger to do the job 2. Find the break line that is causing the problem and trace it from the breaks to the break Master cylinder. 3. Take a piece of steel pipe (standard break line) and use the pipe-bending tool to shape it to look exactly like the pipe you are replacing and use the pipe cutter to cut it to length (if you don't use a bending tool or a pipe cutter, you can cause a crimp in the line and your breaks will not work) 4. If you are replacing the entire line (recommended) remove the line from the breaks and drain off the fluid. 5. Flange (widen the pipe end) your break line at the end closest to the breaks so that it fits over the connector (like the previous break line was). 6. Connect the new break line to the breaks using a new connector (same type as the previous break line. Make sure that the rest of the break line is supported near the original line to keep from ruining the new line -- if it bends or crimps your breaks may not work. 7. Remove the old line from the mounting brackets one at a time, and replace it with the new one as you make your way up the line to the front of the car. Doing this one bracket at a time will help you make sure you are mounting it properly, and gives you a chance to inspect the mounting brackets as you go. If a bracket is bad (and won't secure the line) replace the bracket with a new one -- you don't want your new break line falling down and getting ripped off your car when you hit a pothole. 8. Once you get the line mounted all the way to the master cylinder, complete the removal of the old line, and attach the new one like you did at the breaks-end of the line. 9. Double-check all of your connections and make sure the mounting brackets are all tight, then bleed the break line to remove the air. (it's probably best to bleed ALL of the break lines to make sure you have not introduced a bubble anywhere -- this can keep your breaks from working properly) 10. Once the lines are bled, and everything seems to be in order, jump in the car and hit the breaks REALLY hard -- like you are slamming your breaks to save your life. Check the lines again to make sure they did not leak anywhere (especially at your connections where you had to flange the pipe). If there are no leaks, you should be good to go. If there is even a small leak anywhere in the line or at your connections you should go over the connections again to make sure they are secure. Once you have your lines tight, bled and have double checked that you can slam the breaks without causing a leak, you should be good to go.
I do not recommend doing this work yourself -- it is very difficult to do without a professional lift (as you will need space to work and jack stands don't give you much room). It is also a VITAL part to the safety of everyone in the car ... and if you don't have a lot of experience it is easy to miss something and put yourself at risk. A professional shop and get this job done in a lot less time, and with a lot less risk than an at-home mechanic, so it is probably worth the price. As I said before, the 10 steps above are a GENERAL OVERVIEW of the process -- not an exact science to follow -- I probably forgot to put some information there ... so PLEASE (if you are going to do the work yourself) get a manual to be sure you have all of the steps correct. I HIGHLY recommend that you take it to a mechanic, though (I do a lot of my own car repairs, but I don't trust myself with the break lines -- they are too vital to my safety ... and a pain in the neck to replace without the right equipment)
May 29, 2011 | Buick LeSabre Cars & Trucks
How do you change the rear brake line that goes between each wheel, the brake line that is metal..
Don't do this unless you have skill at and tools to repair flair pipe. You will need the special tubing wrenches as well. The fittings/pipe are probably rusted and - frankly - it will be a night mare getting the repair done ... and then the 'fun' begins when you try to get the air out of the line.
Mar 19, 2010 | 1999 Chevrolet Blazer
Plastic separator missing
It is a tedicous process but it can be done. Disassemble the unit (remove the gear cover). remove the cutters and use an end plastic and place it where it is most needed, usually somewhere in the center of the cutters. Make sure the cutters are oriented in the same direction so as not to jam the paper. Reassemble in reverse order. Make a diagram of the preassembly and use it to reassemble the unit. Take your time. Perhaps you could request a replacement plastic. I just used a plastic washer on the ends. I do remove shredded paper once in a while but that is just preventive maintainance. Hope this helps.
Dec 12, 2009 | Royal 10X Shredder
My cutters don't lock on to the pipe when tighting down on pipe wheeler #90750 they seemed stripped is there anything other than buy new one some kind of replacement kit for the quick realese anything
I am not sure what brand that is but I have been plumbing for over 20 years and still use the origanal set of cutters I started with. They have been rebuilt many time so parts should not be hard to get.
Apr 23, 2009 | Plumbing
Pipe cutter is crushing the asbestoes cement pipe
I think you are supposed to rotate the cutter around the pipe. If this is so then use a small amount of pressure and then rotate, repeat until pipe is cut.
The cutters could be blunt in which case they must be replaced.
Mar 05, 2009 | Wheeler Rex Pipe Cutter No.29908
Powershed 480
The 480 is a high end shredder but most of your questions depend on the load it has been under for the 6 years. I would check the cutters for wear before buying.
Jun 11, 2008 | Fellowes Powershred 480 Shredder
Cutter Tools Logo
905 people viewed this question
Top Cutter Tools Experts
Are you a Cutter Tool Expert? Answer questions, earn points and help others
