Question about Intel Computers & Internet
Starting problem,while smps is ok - Intel Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Are all plugs in right with power
Posted on May 25, 2014
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Thanks.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
I have dell system give smps problem so i chane smps but system not start
if u want to check ur smps then take a small wire short rin no 3&4 that is black and green if fan of smps works then smps is ok
but is smps is working then problem is with mosfet on motherboard u can check it with the help of multi metter
Jul 05, 2012 | Intel D845GVSR Motherboard
I have compaq power supply "PS2018", Part no
open smps take a pin & insert in green end & th other n black end.so if fan runs u'r smps ok & pc will be ok
else replce by new smps
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 18, 2011 | Compaq Computers & Internet
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
My Smps is ok, when i switched on smps fan and processor fan not on
Check Following Instruction:
1. If your SMPS ok, Check 20 pins cable connect properly to the motherboard, or Fan 4 pin connect to the motherboard.
2. And Start your Motherboard. It will OK.
Apr 13, 2010 | Intel Motherboard
I have a D946GZIS motherboard. It does not boot whenever i switch it on and press the power button. Also the power led is not glowing. What must be the problem..? pls help ..
Starting at the begining. The wall socket, the plug, the cable, the power socket on the SMPS at the back of your PC, the SMPS, the Output connectors from the SMPS to the motherboard. The power LED not glowing means that the power is not reaching the motherboard. Disconnect and reconnect the power connector on the motherboard. start. No start. Does the fan on the SMPS work? If yes then all components before the SMPS are doing fine. If no then most likely connection socket power cable to the SMPS may be the culprit. This has a lot of load on it. The PC and the monitor both take power from this socket. the answer to your problem lies in the answer to my question whether the fan starts in the SMPS or not. If yes then there is no output from the SMPS and the SMPS need to be given the due attention and if no then there is no power input to the SMPS and various cables and socketc need that attention. In case you need to and can remove and open the SMPS look for bulged or burst capacitors. If found, replace them. Those round cylindrical components.
Nov 27, 2009 | Intel D946GZIS Motherboard
Akai 25'' TV no power from SMPS. voltage available up to filter capacitor. No smps output. smps power transistor ok. Please responce nagarajak60@yahoo.com
try to check its high voltage section for axed HOT or flyback. Also check its regulator. Maybe start up resistor or check the chopper circuit. You should at least have an standby voltage on the secondary side.
Oct 28, 2009 | Televison & Video
My system no longer starts up. i would like to reinstall my xp .
Check the SMPS, if the SMPS fan rotates that means power +12V is OK, if not probably you need to repair the SMPS, let me know the symptoms
Oct 08, 2009 | ZT Group CISNET A7050 PC Desktop
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
Computers & Internet Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
