Question about ASUS 14 led i3-2310 laptop p43exh31
When i pluged in my hcl laptop adapter the power led was blinking
Hcl me icon l 1044
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • ASUS Expert
  • 150 Answers
When the battery is drained, the power-led blinks for a while until the battery has a few percent of charge, it will then go to solid red.
Posted on Feb 01, 2014
My hcl laptop power led blinking please help me now
Does the laptop power on at all? Im assuming it will not charge. This could be a faulty charger or an issue with the charge port inside your laptop. See if you can borrow a charger from someone. If your problem still persists I would recommend buying a new charge port for it.
Dec 26, 2013 | Toshiba Satellite A305D-S6848 Notebook
My acer 4720z cannot turn on anymore and the adapter pluged correctly but no power enter the system
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 17, 2013 | Computers & Internet
Can't get the laptop to come on.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 25, 2013 | Gateway M305CRV Notebook
Crazzy compaq 6910p when the battery is first pluged in all the lights blink, Only one led stays on and its a green speaker. if i hit the power button the charging light will blink 8 times. the speaker...
Your battery is bad and causing a problem. most likely it is feeding an incorrect voltage into the computer. replace teh battery and it should fix the problem. If you have already replaced the battery with a new one the charging system is faulty or the AC adapter.
Dec 23, 2010 | Computers & Internet
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Compal RM CY25 Laptop. new battery won't charge.
Unfortunately, the charger socket in the motherboard does not drive electricity to the battery to get re-charge it. It is a typically motherboard problem(Do not confused with a power jack problem). I can not be repaired it.
Two options work always hook with power adapter or get ride of her.
Jan 30, 2010 | Computers & Internet
In power adapter, blink the LED (adapter ADP70EB) and laptop is not powered. If laptop is not conected, the green led of ADP light normal ...
I guess first problem is Adapter Power can not established to run laptop.Or fault your laptop motherboard power regulator circuit .Repair it and check Adapter other laptop.
Nov 15, 2009 | Dell Latitude C640 Notebook
Mainboard shutdown
Never do that to fuses, search the web (especially the site of your laptop's maker) for common cures to your situation, and failing diagnosis recommending a particular cure, don't do stuff at random.  That sort of thing sort of sounds like a battery issue; won't the thing come on with no battery, but the power power connected?
Sep 10, 2008 | Intel Motherboard
ASUS 14 led i3-2310 laptop p43exh31 Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
