Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Windows does not start up.error code 0x0
Startup repair has tried several times but still cannot determine the cause of the problem. error code 0x0
  • 37 Answers
Try booting into "safe mode" It's hard to catch safe mode, but after your computer just powers on, press the F8 key and hold it. If you get a keyboard error you did it too soon. You should see something which says advanced boot options. See if you can boot into safe mode and transfer your files to a USB key or USB drive. It sounds like your software is messed up. If you're not able to boot into safe mode, the problem is more serious. Perhaps you recently made some changes in the bios or UEFI? When the system boots hold down the delete key, or the F1 key, and try to get into the bios/UEFI. Look for an option which says "restore defaults", save and exit. There are two different settings for SATA drives, try both to see if you can get your system to boot.
Posted on Dec 26, 2013
Laptop loops Start Up Repair
your HDD is corrupted ... take out your HDD and check another HDD .... if the new HDD is working then your HDD is corrupted.
Aug 15, 2013 | Sony VAIO Computers & Internet
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
"Windows failed to start. A
It sounds to me like the harddrive has errors on it. First, I would try completely reinstalling windows with the windows disk. If that does not solve the problem there are several pieces of software that are much stronger harddrive repair solutions than the built in Windows one. Try this one, it is free for 10 days. You will need another computer (friend's computer?) to download and burn this software onto a CD, then put the CD in your computer and boot to it by pressing any key when it asks you to.
http://www.ntfs.com/boot-disk.htm
Sep 03, 2011 | Dell Inspiron 14R Laptop Computer (Intel...
My lap top is rebooting and error code showing is 0x0
0x0 isn't an error code it simply indicates the test that was run passed successfully. are you saying that it will not start after going through the recovery console? insert your cd and after booting to it, select repair windows installation. click on command prompt and type chkdsk c: -f
Dec 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Windows fails to start. Startup repair is unable to repair.
insert a WinXP Cd in the CD rom drive and restart and let it boot from the disk, let it install the OS again...format the HD (u will lose all data there but ur machine will come back)
Feb 18, 2010 | Toshiba Satellite A215-S4747 Notebook
Windows Error Recovery message on my Gateway M-6309
boot your pc by using minixp and copy your data to usb flash and then format it and install new operating system
N.B get mini xp from Hiren 10 CD
regards
Jan 24, 2010 | Computers & Internet
Error code at startup
Re: windows Vista will not start I had the same problem and came across this solution that worked for me as well: 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Apr 11, 2009 | Computers & Internet
Acer Aspire 3693WMLi -Launch startup repair
Try to boot in safe mode. From a cold boot, hit f8 till it gives you several options including "safe mode". Do that and if you can boot to windows let it do it's stuff before restarting normally. Good luck
Aug 29, 2007 | Acer Aspire 3000 Notebook
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
