Question about HP 1020 Plain Paper Thermal transfer Fax
Printer cartridge door
I'm having problems opening the printer cartridge door.  Is there a release button somewhere?
  • Anonymous Dec 12, 2007
    I don't know how to change the ink cartridge and I can't find a user's manual anywhere.
Here's the manual: http://pdf.textfiles.com/manuals/FAXMACHINES/Hewlett%20Packard%201020%20Plain%20Paper%20Fax%20Machine.pdf
And the fix is to firmly grasp both sides of the front panel at the top. Then pull hard away from the base of the machine. Believe it or not, there are two metal clasps that hold the panel down tightly. Once you pull hard enough for the panel to open it will sound like the damn thing broke. It likely hasn't -- mine didn't. After the panel is open, lift the paper guide panel to expose the ink cartridge. If your machine is plugged in while you're performing your surgery, the ink will move to the right and be exposed enough to remove from the machine.
Posted on Jan 19, 2008
Cartridge install
Press the cartridge-door release button, and then open the cartridge door. Make sure that the door is completely open.Insert cartridge properly inside, close the door...
For more info pl visit you tube link:
https://www.youtube.com/watch?v=vjmKxIqyjWk
Sep 17, 2013 | HP LaserJet P2055d Printer
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    I have light in this ( !) what that is mean?
    If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
    If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
    You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
    Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
    Hp f30 has new ink cartidge and paper but ink button still flashing and not printing alignment page.
    Here are some steps that can help you resolve the problem.
    Close the cartridge access door securely, if cartridge access door is open even slightly, the print cartridge light will blink.
    1. Open the cartridge access door, once carriage moves to the center of the printer.
    2. Check inside the printer and make sure that there are no obstructions that are preventing the cartridge access door from closing , if there's any obstruction remove it.
    3. Close the cartridge access door completely.
    Do the Print Self Test
    Press and hold the Cancel button, and then press the Start Copy Color button
    Release both buttons at the same time
    If the issue persists, Make sure that the cartridges are installed
    2. Wait until the carriage is idle and silent
    3. Check the cartridge slots in the carriage to make sure that the cartridges are installed.
    4. Try to reinstall it again.
    5. Lightly press down on a cartridge to release it, and then pull the cartridge toward you out of its slot.
    6. Check the nozzles on the cartridges to see if the protective tape is still attached
    Note: Do not touch the copper-colored contacts or ink nozzles
    7. Hold the cartridge by its sides
    8. Slide the cartridge into its designated slot at a slightly upward angle.
    9. Press the cartridge inward until it snaps into place
    10.Close the cartridge access door
    If still the problem persist contact HP for the service.
    I hope this will be able to help you.
    Thank you for choosing Fixya
    Mar 10, 2011 | HP DeskJet F380 All-In-One Printer
    Ink absorber almost full
    Need to reset waste ink absober full.
    Follow this step to reset waste ink absober full.
    1> download iptool to reset waste ink absober full
    Download here ----> Service tool 1
    Service tool 2
    After ypur download finish
    > turn off your printer power switch
    > open your printer cartridge door
    > press and hold on/off button (never release)
    > turn on printer power switch
    > push your printer cartridge door switch with pen or anything can press door swith.
    > then release on/off button
    > close open door
    > then press on/off button 1 more
    now your printer is in normal mode( no orange led blinking)
    Then you can use ip service tool to permanent reset waste ink absober full.
    Hope this guide can help fix your problems
    Extra download
    Fixwasteinkabsoberflowip1000
    Jul 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
    There is a message that ink absorber is full and contact tne service centre.
    Service tool 2
    > close open door
    Extra download
    Fixwasteinkoverflowip1000
    Jul 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
    My canon ip1980 appears error 5100 on my display i will replace my data strip but the problem still occurs. What should i do. Tnx
    This problem is between waste ink absober full and ink cartridge.
    Firstly your need to reset waste ink absober full.
    Service tool 2
    > push your printer cartridge door switch with pen or anything can press that door swith.
    > close open door
    IF after reset your waste ink absober full, problems still apppear error5100
    > change your ink cartridge with the working cartridge
    usually error e5100 due tow problems above
    Extra download
    Jun 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
    My toner cartridge refuses to come out. Is there a release somewhere that isn't working when I open the access door?
    Yes, the release is on the black lever connected to the door on the left. If that won't release it you will need a new developer drive gear, #LM4225001
    Jan 12, 2010 | Brother HL 5170DN Laser Printer
    Light is flashing and will not print
    dude..u didnt mention printer's make n model nyhow give a try to dis one..
    Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
    Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
    If it prints ..u r the master !!!
    Best of luck
    Remember if there is any blinking light,,the printer wont prin..
    if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
    ALL THE BEST
    May 08, 2009 | HP DeskJet 930cm InkJet Printer
    Can't remove used ink cartridge from G600 Printer dock???
    I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
    Mar 20, 2009 | Kodak Easyshare G600 (1633379) Dock /...
    HP 1020 Plain Paper Thermal transfer Fax Logo
    78 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
