SOURCE: toshiba estudio 350 the error
If wait warming is occur on the panel, and it wouldn't change to ready, then fuser unit is the cause. Need to check the themistor and themostat on fuser unit.
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
SOURCE: how to reset error code f14 in the photocopy
guys please help me how reset error code F14 for Toshiba copier model no. 167
SOURCE: toshiba estudio 351c error code
Hi [CE40] Image quality control test pattern abnormality (1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M and C, and under 220 for K are defined as low-density pattern abnormality. (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to check if the high-density pattern abnormality occurs for each color and identify the color which pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "0" (Invalid). (5) Perform "Enforced performing of image quality open-loop control (05-394)". (6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal. (7) Replace the image quality sensor. (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "1" (Valid). (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is completed normally. (Error [CE40] does not appear.) (10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576). Good Luck Regards
I hope that this will help you
