Question about ASUS P5P800-VM Motherboard
Cpu fan speed
Noisy processor fan
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 17 Answers
1. Check if something like power supply wire have bangin in there.
2. Clean : Try to use lighter fluid to loosen and clean the dirt inside the processor fan but first disassemble the fan from the heat zinc of the processor. flip the fan and you will see the bearing and motor, drown it with fluid, and rotate the fan so the dirt will loose, after some spins, try to spill the fluid inside the fan. then assemble and test.
Posted on May 04, 2014
2 Suggested Answers
SOURCE: cpu fan noisy/chip fan fail error messages
I had tons of problems with these Asus chip fans. I asked Asus to deliver 12 replacements (as I had a lot of pcs at that time with the same problem) It worked well, but placing a tiny heatsink well glued to the chip worked well also, as long as one does not want to overclock the thing. It's true that the temp raised a bit, but it remained pretty much in the tolerance area.
Posted on May 21, 2008
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
Overheating intel 915 2.8ghz processor 50degrees
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Fan noisy at steady high speed
Try replacing the cpu fan. The reason why the cpu fan is noisy its because the bearings are rusty and need some lubricants. But in this case you have to replace them. For me there's no need to upgrade your bios. Its just a hardware problem.
Jul 12, 2010 | Compaq Computers & Internet
Varying Fan Noise
cpu fans are smart fans it works according to processor's temprature. more processing of cpu makes fans speed faster...slowing down the speed of cpu fan may affect your cpu's performance
Sep 24, 2009 | E-Machines eMachines Desktop PC
Heating problem?
You could get an Intel Water Cooling kit
Jul 11, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Noisy fan
You need to replace the fan. Measure the fan you have now and buy one the same diameter. Then remove the old fan and put in the new fan.
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
CPU fan issues
The fan may not stay on all the time - its a feature of laptops to help save power. The fan is also variable speed. As the CPU gets hotter, the fan speeds up. When the CPU isn't being used as much and is cooler, the fan slows or even stops. It turns on to full speed when you first turn the laptop on as part of the BIOS system check.
The noise is another issue. You could have a broken "fin" or fan blade. The bearing could be going out. Something may have simply "crawled" inside the fan's output vent. In any case it may be worth your time to have a professional open up the laptop and look at the fan. I have heard a LOT of noisy laptop fans in my day, and believe me it's not the worst thing to put up with.
Mar 19, 2009 | IBM ThinkPad T42 Notebook
My hp pavilion a6110n product nogg781aa .Has anoisy cooling fan .How do I chang it.
If it's the processor fan that's noisy you can purchase a replacement. The fan and heatsink are normally a complete assembly you can find from many vendors online. This computer has a type AM2 socket; you need to make sure to get a cooling fan for that type. Be sure the replacement will fit into the same space as the original.
If it's the power supply fan thats loud, there may be a couple of possible causes. It may just be a noisy fan, in which case you can replace the power supply. Make sure to get one that has at least the same power rating as the original. Or the fan may be running at its maximum speed. I don't know about this computer in particular, but many computers control the fan speed depending on how hot the processor is (determined by sensors built into the main board). If the fan is running at its top speed, it can be quite noisy. This might be due to a defective power supply or problems with the fan control on the system board
Nov 19, 2008 | Computers & Internet
Cpu fan
If you're talking about the fan on your processor that is very noisy and you already clean it and still the same
you will need to replace the fan already because sooner or later that fan will not function properly anymore
and it will cause your system some overheating....
Don't forget to rate the solution FIXYA thank you...........
Nov 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
ASUS P5P800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
