Question about Transcend Computers & Internet
Flashing blue light turns on and off
Hello, When in connect my hard drive to my pc the light flashes for a second and then it turns off. I tried several times but it's not working. Thamk you
  • 24 Answers
Try using another usb port ,or another pc, also has it been recently dropped? if you dont know then when you connect it and it make a whooshing noise then its fine, but if it make a grinding noise even if its slight then the disk is damaged and unusable.
Posted on Dec 26, 2013
SOURCE: WD MyBook World Edition 500GB Model: WD5000G032
I had the same problem as everyone else here - blue rings go out and then - nothing.  I called WD's data recovery partners and got quotes from $700-$1500 to recover the data because it is a network device!  Thanks Kellydam for the first clue.  I took my MyBook apart (start with rubber seal around the edges, then "unhook" it top and bottom on front of device by inserting a flat tip screwdriver through middle slot).  I purchased a Gigaware SATA enclosure and pluged it in to my computer.  Nothing.  I didn't get access to my files until I used Explore2fs to view the ext3 file system.
Posted on Apr 24, 2009
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
bob_computer
  • 3153 Answers
SOURCE: When I supply power to the hard drive, the green light flashes.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
  • 60 Answers
SOURCE: Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Posted on Dec 25, 2009
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
WB 1TB blu light flashes but wont startup
The my book world has 3 different kinds of flashes.
1. Fast flashing (every 3 seconds) - Which means it's going into standby mode.
2. Slow flashing (every 5 seconds) - Which means it's in standby mode.
3. Alternative flashing between inner and outer ring - Means RAID failure (this only applies if you have the RAID compatible version [dual drive my book world])
4. Simultaneous flashing - Means the drive is overheating and the drive needs to be shut down.
Try resetting the drive, using the link below for guidance (this will not effect your data). If the drive does power-up, you will need to change the IP to static, if you had it that way before and you will need to login with the following login details: Username: admin | Password: 123456
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1521&p_created=1172595028&p_sid=UhG4a-Sj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD0xNTIx&p_li=&p_topview=1
Jan 19, 2010 | Western Digital 500GB My Book World...
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Flash drive not lighting up and not being read
Hello aaron_s_robe,
Sounds like the flash drive may be faulty. You may try plugging it into another USB port on your computer, if that doesnt help try plugging it into another computers USB port.
If after trying the above doesnt work. Your drive is most likely bad.
Sep 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
Blue light flashed on the portable hard drive for a couple seconds.How do I know if all files were transfered? Nothing on screen showed up? I have a HP laptop.
If your portable hard drive was set up as the "H" drive, go to My Computer (in Windows XP), or Computer (in VISTA), select your "H" drive and view your files (if there).
Jun 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
TrekStor 160gb Harddrive wont turn on
Try to turn it off and quickly turn it on again in a split second.
And buy a second hard disk just in case.
Sep 28, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Jun 06, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
152 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
