Question about Honda Water Pump 2 Inch IntakeOutlet 5 Hp Honda Engine
Not getting any pressure at nozzle.
Honda pressure washer 2600 psi. Not getting any pressure at nozzle. Five silver balls have fallen out from somewhere I cannot determine.
  • josh1111 May 11, 2010
    those are bearings from inside the pump, youll have to take the pump out and apart
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
Posted on Sep 08, 2009
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Honda gcv160 wont dispence detergent
it will not draw soap while using pressure take out the nozzle or use the large black nozzle
Jun 09, 2012 | Craftsman 2600 PSI Honda Powered Pressure...
Honda 2600 psi pressure washer
are you sure when the old pump went bad it didn't plug up the nozzle and or trigger
Jun 06, 2012 | Garden
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
My Honda PSI 2600 will not suction the solution?
1. Make sure that you are using the black quick connect nozzle supplied with your machine. If you have a vario nozzle (turns back and forth to adjust the spray pattern), you are going to want to pull out on the nozzle to get the machine to a low pressure setting.
2. If you still have an issue, take a paper clip, straighten it out and stick it into the hose nipple on the pump where your chemical hose is connected, push in and out a couple times to free up the ball and spring.
3. If it still doesn't work, take the chemical nipple assembly apart, make sure there is a o-ring, ball and spring. If one of these are missing you are going to have to order a chemical injector repair kit. If you have all the parts you can streach out the spring a little and put it back together which should make it work.
Oct 14, 2010 | Honda Black Max 2600 PSI Pressure Washer
Honda Water Pump 2 Inch IntakeOutlet 5 Hp Honda Engine Logo
673 people viewed this question
Top Honda Tools & Hardware - Others Experts
John Loiselle
Level 1 Expert
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
