Question about FSPro Labs Event Log Explorer
Event log explorer serial key - FSPro Labs Event Log Explorer
Accordion Trainer Serial key
The software comes with its serial key in the package. If you bought a downloadable version, then you should get all the keys (serial, activation) in an E-mail sent to you by the vendor.
In any event, FixYa does not give keys to other vendor's software.
Oct 16, 2013 | Artillery Accordion Trainer
Logging Off
how long have you waited for it to log off? sometimes it's performing background operations i.e. updates or trying to close a program. hit the windows key and the r key at the same time and type eventvwr and press enter. look at your system events and application events and make sure that it's not having a problem closing a program. this could be what's causing the laptop to hang @ turn off.
Jul 18, 2012 | Compaq Computers & Internet
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Error reading event file
The EVT files include the event log messages as they are stored by the system. Each message is composed of an ID (that is, the message itself) and a number of insertion strings. The IDs are translated into strings through the use of messages DLLs.
All the application event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ Application
All the system event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System
For example, the TCP/IP service's message DLL is defined under the following registry entry:
Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\TcpIp Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ netevent.d
Therefore, all the TCP/IP event log messages are defined in the DLL netevent.dll.
When the user double-clicks an event for which the message DLL is not defined in the registry, the message string cannot be displayed and the following message is displayed: The description for Event ID (51) in Source (aservice) could not be found. It contains the following insertion string(s): ... Below is a description of a way to read the system event logs of a computer with WINS on a computer without WINS. This sample can be adapted for any application or system component.
WARNING: Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to reinstall Windows NT to correct them. Microsoft cannot guarantee that any problems resulting from the use of Registry Editor can be solved. Use this tool at your own risk.
The following operations are required:
  1. On the computer with WINS, run REGEDIT and select the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\Wi
  2. On the Registry menu, click Export Registry File and select a file name (for example, Winsreg.reg).
  3. On the computer without WINS (for example, the one used to read the system event logs of the computer with WINS), run REGEDIT. On the Registry menu, click Import Registry File and select the file Winsreg.reg previously saved on the other computer.
  4. You should now have the following registry entry on the target computer (that is, the one without WINS):
    Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ EventLog\System\Wins Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ winsevnt.d
    You now need to copy the file defined in the EventMessageFile registry value in your System32 directory. If X: is mapped to \\wins_server\admins$, you can run the following command: copy x:\System32\winsevnt.dll %SystemRoot%\System32\winsevnt.dll
    Of course, the file may be copied somewhere else, but in this case you need to edit the EventMessageFile registry value manually so that it points to the directory with the DLL.
  5. Close all the instances of the Event Viewer and rerun the Event Viewer. You should now be able to dump all the WINS events.
Nov 14, 2009 | Cosmi Print Perfect Platinum
Getting error message: Internet Explorer is not responding. This is IE version 8.
Go into the event viewer by entering eventvwr in the run dialog box.
Locate the application and system tabs. There will be an event ID relating to the problems. You may need to clear the logs first, don't save, then reboot and try to connect.
On another system that you have, go to Microsoft Technet and enter the event ID and keep the description handy.
If Microsoft doesn't have a fix, then you'll have to do a system restore to when the internet worked last.
Aug 02, 2009 | Microsoft Internet Explorer 8
Please guide me the steps to disable the" print the event log"
If you don't want see a printer notification event in the event log you can disable that..
Start regedit and find the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers".
Add "Eventlog" and set the value "Reg_DWORD" at "0".
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Jun 25, 2009 | HP LaserJet 1020 Printer
Please guide me the steps to disable the"print the event log"
You will need to edit the registry to do this.
Jun 24, 2009 | HP LaserJet 1020 Printer
Windows is activated but will not let me log in
dear,
switch to Safe Mode and then delete the login except the administrator one...then try again..
hope it will work..
regards,
May 11, 2009 | Microsoft Windows XP Home Edition
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Computers & Internet Logo
56 people viewed this question
Top FSPro Labs Computers & Internet Experts
David Payne
David Payne
Are you a FSPro Labs Computer and Internet Expert? Answer questions, earn points and help others
