Question about Water Heaters
Reliance 502 Hi my water heater seems to be leaking from the bottom or running water near the drain also might be leaking from the value that has insulating around it also near the bottom of heater but I would say it is closer to the heat gauge then the bottom of water heater. Is this normal or do i have a problem?
    Top Expert:
  • Water Heaters Master
  • 35,614 Answers
The problem is that your water heater is leaking and, depending upon its age, may be in need of replacement.
Posted on Dec 26, 2013
  • 71 Answers
SOURCE: Reliance gas water heater 40 capicity, has a leak on the top
Most likely only one of the pipes is leaking but weaping enough to cover the top and indented places near both inlet and outlet. This leak has most likely penetrated all the insulation and is a problem throughout the tank wrap insulation...If you are able to blow air continuously long enough to determine which connection is leaking then fix it. It will likely to take quite a while to dry out all the insulation if the water has migrated down into the tank wrap... If you determine that the insulation is waterlogged, you may be able to drill several small holes in the external cover.
good luck
Posted on Jan 06, 2009
  • 68 Answers
SOURCE: Is it normal for my electric hot water heater to "sweat"?
could be a pin hole leak some where on the tank and the insulation is absorbing it for now if it is older then 6 years and u havent replaced the anode rod or flushed the tank once a year you should probibly look to replace it
Posted on Mar 15, 2009
  • 10865 Answers
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
Posted on Apr 27, 2009
  • 252 Answers
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
Posted on May 24, 2009
  • 71 Answers
SOURCE: My Reliance 606 40 gallon water heater only heats
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Posted on Jan 04, 2010
The water heater leaks
Once it starts leaking, that is it, replace it. I strongly recommend that you put a PAN under the new unit, as it will also leak in 8 to 10 years...pan needs to be plumbed into a drain....not expensive, but water damage is...
Sep 10, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water heater is constantly runnin and sds like water is running. the noise seems to be coming from the emergency valve area. there is water pooling around the bottom of the heater
Open following link to identify specific leak and remedy:
http://waterheatertimer.org/Water-heater-is-leaking.html
If TP valve is leaking: replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
If tank is rusted and ready to rupture, then turn water heater off:
Over next days, turn water heater on for short periods to make hot water when needed, then replace water heater.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | RELIANCE ELECTRIC WATER HEATER
Water coming out the top of each hose connection to hot water and cold...help. electric is cut off water cut off.what can i do?
attach a hose to the hose connection at the bottom of the heater and open the valve to drain the heater...
heatman101
Feb 01, 2011 | RELIANCE ELECTRIC WATER HEATER
Reliance 501 - purchased house a few years ago don't know how old it is - water is dripping from bottom near plate can feel a small rectagular hole with what seems a small piece of metal in the middle -...
unfortunately not, if the tank is leaking from the casing, it needs to be replaced. i would suggest, if your not paying water tax, you can run the tank for as long as you like, just divert the leaking water into a floor drain. but i do highly recommend getting a new tank. that drip can turn into a flood in a matter of days, all depending how bad the inner wall has corroded.
Jun 20, 2010 | Water Heaters
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
My reliance 606 water heater drain valve is leaking..what size do I need to replace it
You are going to have to drain it anyway. So drain it and take the old one with you to get a new one. In case you don't know turn the breaker off before you drain it. If you don.t you will melt the heating elements. They get too hot out of water.
Jan 06, 2010 | Reliance & Drain Valve for Gas Water...
I have a Reliance 501 gas hot water heater that needs a tank cleaning. Scale is showing up in faucet aerators. Is it still comon practice to delime hot water heater tanks? If so any recomendations?
hook up garden hose to faucet @ the bottom of the tank and drain the hose to the outdoors or down a floor drain and open the valve , leaving the cold supply valve on , let it run until it runs clear , this will get rid of some of the sediment deposit that form at the bottom of tank , is the most effective way i know , good luck
Dec 31, 2009 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
119 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
