Question about Canon LASER SHOT LBP 3300 Printer
Paper jam error 1
I placed a5 papers cutting it to a4 and then kept.it took all papers and now iam unable to remove it.... please tell me with diagrams where and how to remove it
    Problem Solver:
  • 8 Answers
Just open the back cover and clear the jammed paper..http://cweb.canon.jp/manual/lasershot/pdf/3300-e-user.pdf
Posted on Dec 26, 2013
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: I have a Canon Pixma
It was covered by Staples Extended warrantee and they exchanged it.
Posted on Nov 15, 2008
  • 117 Answers
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Posted on Oct 09, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
Canon irc3080i
first remove all paper trays and inspect for paper behind the tray area and inside the machine
second verify if the paper trays are set to the correct paper sizes this is easy just look at the screen under paper trays and all trays should tell you what they are set to
Oct 29, 2013 | Canon Office Equipment & Supplies
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
I had the Bro 8840D repaired following a paper jam. I am unable to get it to pull paper through. Says paper jam, but no jam exists. The tech repair shop said a switch had been flipped when the first jam...
okay, try this...clear the paper jam message and try to make a copy using the manual bypass (MP tray) located on front of machine. if copy comes through okay, then chances are you have a problem in main cassette area. pull cassette out, and make sure the rear stop inside cassette is not pushed too tightly against rear of paper stack. should leave about 1/8" gap. if thats okay, then sounds like you may need your paper pickup roller replaced. sounds like your repair shop just fixed the error, not the cause of the error.
hth,
razors
May 24, 2010 | Brother MFC-8840D All-In-One Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
When I try to print on A4 paper the Canon printer pulls on the right side of the paper only and it jams. I can still print on the small sheets (A5?) or on my 4 x 6 photo paper.
Check to see if this will affect your guarantee and if so would probably not go ahead with it.
Protect yourself from shock by disconnecting the power cord from the back of the Canon printer.
Unhinge the back access panel of the printer. .
Look through the opened back panel and look for paper or any other object that should not be there. Remove any paper or obstacle you find jammed there.
Close the back access panel. Make sure that it latches back into place.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel and look for paper or any other object that should not be there
. Remove any paper or object you find jammed here. If you find paper pull slowly or the paper will rip and create a major problem.
Close the front access panel. Make sure that it latches back in place.
Put the power back on..
Jul 14, 2008 | Televison & Video
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon LASER SHOT LBP 3300 Printer Logo
80 people viewed this question
old marine
old marine
