Question about Sanyo Vacuums
Sanyo sc-s260 I don't know how to install the dust paper in it?nHow to open the top?
2 Suggested Answers
SOURCE: Emptying an sc-505
push the button
Posted on May 29, 2008
I have Ridgid wet/dry shop vac, I was vacuuming
Did you have a paper/cardboard filter attached to the top part of the unit? Sounds like you didn't have a filter or the silicate material got past it and into the motor and windings. Bad news if this is the case. Try taking the top part off, turn it on to see if it runs without the bottom tank section. Double check to see if your vac has a fuze. If it won't go on you'll need to dismantle the upper unit and clean it all out. Hand turn the motor and see if it easily turns or is sluggish. My wife used my wet/dry vac without the filter and wrecked it with sheetrock dust into the motor. I dismantled the top, cleaned it twice and it's still no good. By the way, generally you have to take the paper filter out if you are vacuuming wet up. If you leave the paper filter on and vacuum wet up, the paper filter will get wet, shred and get pulled into the upper motor unit. A wet/dry vac isn't really made to pump water (by the gallons) out of places, so don't expect that. Okay yes you can often hook up an outlet hose to the drain port at the back of the tank and vacuum quantities of water, but it's not really made to do this.
Aug 28, 2014 | Vacuums
Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Jul 31, 2007 | Sanyo Transmax SC-150 Bagged Upright...
How do you change bag
Hi! Below are step-by-step instructions on how to change the bag on your vacuum. This vacuum takes a Dirt Devil Type D replacement bag. I have included a link to the instruction manual, as well as a link where you may go to purchase replacement bags for your vacuum.
1. To Remove: squeeze front panel release lever and pull towards you.
2. Grasp cardboard collar of paper bag with both hands and pull past raised locking tabs on the dirt tube. Dispose of old paper bag.
3. Important: Extend bag away from hole before installing. Press in opening to clear paper away from hole.
4. To Install: Push cardboard collar past raised locking tabs on the dirt tube with both hands. Be sure paper bag is fully extended and tucked in at the top and bottom.
5. Replace front panel by putting the two bottom tabs in the slots on the vacuum. Push front panel so release lever attaches.
http://bit.ly/1DEkilx
Type 3 Pack
Hope this helps!
Jun 01, 2014 | Dirt Devil Vacuums
Sanyo sc-s260 user manual
I want to clean my vacum cleaner, How i can open my sanyo vacum cleaner model: sc-s260
Dec 26, 2013 | Metropolitan Vacuum Cleaner Vacuums
How do you read the "full bag indicator" on a Meile S7260?
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Apr 14, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
Can't find paper bags SC - P11 or electrostatic micron filter SC - F2 at any retail stores
Try a local vacuum repair shop. Most of the major retailers carry in stock mostly what they sell.
The local repair shop may not have the bags in stock, however they should know where to get them from.
I just checked my supplier here in Canada and they have the bags, but not the filter. Take the filter with you that you are looking for, maybe the store will have a suggestion of a replacement.
Good luck,
Mark
Nov 10, 2010 | Sanyo SC-180 Bagged Upright Vacuum
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
My sanyo power brush is spitting out dust instad of sucking it in
Check for a plugged hose or wand, this is a classic sign of a plug some where between the power head and canister.
Tom
Sep 24, 2009 | Sanyo SC-X1000P Canister Vacuum
Vacuums Logo
32 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
