Question about Toshiba Laptops & Parts s Hard Drive
Please help me with my problem?
I'm trying to reformat my hard drive, but I am getting this message, "Setup was unable to format the partition. The disk may be damaged.
  • Atlanta102 May 11, 2010
    Can you delete all the partitons on the disk and create them from scratch again? Are you formatting as NTFS or FAT? NTFS is usually the better option depending on which version of Windows you are using. Can you provide more info on which program you are using to format the drive?
  • 221 Answers
Toan96, I would recommend that you replace the drive. Why are you reformatting? Was it because there was a problem with the drive? This message you received indicates that there's a read/write problem with the disk.
Posted on May 18, 2009
Disk wil not format/keep dipaying format fail
hi .. nt sure whether your talking about an external hard disk or somethingelse..
But here goes
In detail
Causes
  • If the hard drive is not setup correctly in the BIOS or is not jumpered correctly, this may cause the BIOS and Windows to detect the drive incorrectly.
  • Viruses or spyware program are capable of conflicting with Windows programs such as the format utility built into Windows.
  • If the partition on the hard drive is corrupt or damaged, this would cause Windows to stop the format process or show an error message.
  • If the computer system does not have the latest BIOS and hardware drivers, and the operating system does not have the latest Service Packs installed, Windows may not address or recognize the drive parameters correctly.
  • You are attempting to format a partition larger than 32GB as FAT32 in Windows 2000, XP, or 2003., win7
  • If the hard drive or data cable is physically damaged or defective.
  • There may be a conflict between the hard drive and another device (on the same IDE cable).
Solution please try
It is recommended to low-level format the hard drive to resolve any partition corruption issues that may be present. For directions on how to low-level format a hard drive
If it's an internal hard drive, please ensure that the latest BIOS is installed for the computer, motherboard, or PCI controller card. BIOS updates can be obtained from the computer, motherboard, or controller card manufacturer. The BIOS should be setup to Auto-Detect the hard drive. If there is a Mode option, this should be setup as LBA, Large, or Auto
  1. Ensure that the latest drivers are installed for the hardware in the computer. Drivers for the hardware should be available from the respective hardware manufacturers.
If this occurs on an external hard drive, connect the drive to another USB of FireWire port on the computer. You can also connect the hard drive to another computer system to perform the format. This issue may be caused by attempting to reformat a FAT32 partition as NTFS without deleting the partition first. You will need to repartition and reformat the hard drive
hope this helps you out
Aug 28, 2014 | Electronics - Others
Windows is unable to read the usb
When you formatted the drive for the Mac, you probably used the HFS format. Windows can only read NTFS or FAT formatted drives. You will need to reformat your external drive again. If you use a FAT32 format, all computers will be able to read the drive (Windows, UNIX and Mac - anyway). Note: the FAT32 option does limit the number of files in each directory and the maximum file size.
First back up any files that you have put on the external drive to another disc (your computer's hard disc, for example).
If you are using the M2 external disc for Time Machine backups, you should partition the drive into two sections. Format one to the FAT32 and the other to HFS.
The Disc Utility in OSX can repartition the drive and reformat it. However, sometimes it doesn't correctly format the new partitions. You may need to do some extra step, see http://www.cs.ubc.ca/~pcarbo/macnexstar.html for one set of reformatting steps. In Windows, there is a similar utitily in the Disk Management Control Panel. (Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions (Windows 7)) You can only format the disc to FAT or NTFS with the Windows utility.
Some third-party software is available for changing the partitions on a hard drive formatted for Windows use without losing the data on the disc. I do not know if similar programs exist for OSX.
Some versions of Unix have gparted which will also repartion and reformat a hard disc but can't keep the original data on the drive. (I've used the Windows and Unix partition managers, including Paragon Partition Manager which let me keep my original Windows data on the drive.)
I hope this helps.
Apr 12, 2012 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
How can i format my pc& how change my os from ubuntu to windows xp
The following tutorial will help you reformat your hard drive and reinstall windows. I personally reformat my HDD and reinstall windows at least once every 3 to 5 months. After your first successful reformatting, you'll wonder why you didn't try this earlier. This is one of the first things I taught myself because I knew I was going to make a mess of my system...alot. Anyway, Please note, I am not responsible for any damage although I don't see how you can possibly damage anything whilst reformatting. Follow these steps exactly and you should be fine.
Step 1: Make sure you have your Windows XP disk. I personally delete everything I don’t need, and uninstall all programs that I don’t use. I then make a list of all the programs I still have installed and download all the installers I will need. Also download Spybot Search and Destroy and Ad-Aware but do not install them. I then backup all my important data and all the installers onto a portable hard drive – if you don’t have one you can build one (see HERE how to build your own external hard drive cheaply) or you can use DVD’s or CD’s. Make sure you have everything backed up and then disconnect the portable hard drive.
Step 2: Insert your windows disk into the Master CD drive (if you have more than one) and turn the computer off. Make sure you are disconnected from any networks. You will need to have your cd drive selected as your first boot device. If it not already selected, you will need to go into your bios and set the boot priority to cd/hdd, then with your Windows cd in your cd drive, save and exit bios.
Step 3:
Turn on your computer. A screen will come up saying “Press any key to boot from disk”. Press any key (where’s the “Any” key gone?!). Now wait about 10seconds for the setup utility to be loaded. When asked if you want to set up or repair, hit Enter to set up Windows. Read the license agreement and hit F8 if you agree. If the setup program detects an existing installation of Windows and asks if you want to repair it, hit Esc to skip the repair. The setup program will ask you where to install Windows. Highlight the existing "C: Partition1" partition and hit D to delete it. Hit L to confirm. Next, hit Enter to install Windows on the "Unpartitioned Space". Format the space as NTFS - You will get an option to choose full or quik format. My experience is that quick format is for disk that have previously formatted. If the disk has not been formatted, then you will have to use the standard format option. Usually you will get a popup message "This disk can not be quick formatted" or something along that line. Then continue the installation. Please note: During the installation process, your computer will reboot. You will then see a message to press any key to boot from cd. Do not press any key a second time, otherwise the installation will start from scatch again. Complete the next several screens on the setup process and make sure you do not leave the administrator password blank. After following these steps, setup should be complete.
Step 4:
Firstly you should install your antivirus software, Spybot S&D and Ad-Aware. Also enable the windows firewall by going to Start>Control Panel>Network and Internet Connections>Network Connections (icon on the bottom-right)>Right-click the Local Area Connection>Properties>Advanced tab>Check the box next to "Protect my computer and network...">OK. After this has been done, install all updates from the Microsoft website (including windows XP service Pack 2). Then install all drivers from your motherboard utilities CD. Now it is time to install your programs.
Step 5:
Enjoy the brand new feeling of your Reformatted PC
Hope this tutorial will help some people.
Watch this 5 minute video tutorial before you start...
Jun 24, 2010 | Computers & Internet
Friend sent me a usb stick that I can't open
don't format it...most usb sticks actually have two partitions. That partition that is saying to scan or reformat is the partition that has the usb stick setup files. Open the icon "My Computer" and see if there is another drive listed in there....like drive "K" or something else. Usually once you click on not to format, another windown will open and ask what you want to do with this drive. If the other drive is listed, just click on it to open it and retrieve the files. If it isn't listed, try another usb port or reboot the computer and try again and make sure you have an internet connection to see if there is a driver that is needed.
Jun 11, 2010 | Verbatim External, USB 2.0, 750GB...
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
My emachines will not install windows xp, so i tried to install another windows perfessional and it said the disk has exceeded its limet.
Pop the disk in the drive and set off your install.
When the setup gets to the part where it asks you where you would like to install XP you will need to delete the C drive partition, format the partition and install XP.
XP from a clean install only takes 3GB of hard drive space, so unless you are trying to install XP on a drive which is only 2GB then you have no chance until you get a bigger capacity hard drive.
The information will be there at the beginning of setup telling you how many partitions you have (if any) and how big the drive is.
Remember that you need to delete the partitions that holds the older operating system as all the information is still on the drive, deleting the partition will permanently delete the information.
Regards.
Sep 16, 2009 | E-Machines eMachines Desktop PC
Samsung40 gb harddisk unable to format (SP0411N). But i can read old data. I cant delete anything. cannot delete partition also
Try formatting / partitioning the drive with windows xp setup / installation cd. If you are trying to format or delete partition in windows and its your c: drive you will not be able to do that.
Jul 30, 2009 | Samsung (SP0411N) 40 GB Hard Drive
No operating system - instal xp pro
With what you have done, it seems pretty cut and dry. You hard drive appears to be damaged, which is why your having problems formating/accessing it.
I would recommend running a hard drive test. If you not sure how, I would ask a local repair shop to run a quick test on the hard drive to confirm its bad. Most shop will do this test for free, if you get a hard drive through them. If you wanna go online and get your own hard drive, testing should be less than 30 bucks.
If this helps please rate my solution.
May 10, 2009 | Acer TravelMate 650, 660, 800, 6000, 8000,...
I have 2 drives C:\ and D:\ Im trying to reinstall my windows but my c drive would not allow me to do so. Instead I could only do so on D:\ Now I have three options during bootup: c:\Windows, D:\Windows...
Hi.
Insert the xp CD in the drive.
Where it asks you to choose a location to install xp, just delete both the partition. (default button D)
Then make two fresh partition and install xp in the first one (that is C).
This will solve your problem.
Regards
Faraz
Oct 14, 2008 | Computers & Internet
Problems while formatting
thats a system problem. please try to reformat that drive another time. this sometimes happens due to heat. you can also try reformatting that drive in another pc.
have that drive checked also for bad sectors... you'll never know.
Apr 09, 2008 | Microsoft Windows XP Home Edition
Toshiba Laptops & Parts s Hard Drive Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
