Question about Plumbing
My sons are always clogging the toilet. I have to use Drano about 5 times a week. Is this bad for my pipes?
    New Friend:
    Problem Solver:
  • 10 Answers
It's not idea for your pipes to use Drano too often. Drano and similar products have chemicals in them that prevent corrosion but five times a week is a lot and all that chemical use will take it's toll. I suggest that you try using a good old fashioned toilet plunger as much as possible and only use the harsh chemicals when the plunger doesn't do the trick.
Posted on Dec 26, 2013
What are the most common venting problems for toilets?
What all that means is the sewage pipe going to the street is getting clogged so either snake it with 50 foot snake or go buy so Drain-O (60 ounce bottle costs about $9) and pour 1/5 in toilet and wait 10 minutes then pout 1/5 in Bathroom sink & wait 10 minutes. Keep do that until 60 ounce bottle is empty. Let this stay in pipes for couple hours and your toilet will double flush now its clean with no corrosion, hair, cooking oil, and other debris.
Apr 17, 2014 | Home
Toilet stays full will not drain?
the lever is broken or the valve is stuck
open the tank and check what is blocking the water from flowing into the pipe when the lever is pressed
Apr 16, 2014 | Home
Tank takes a long time to fill
check for a clog in the toilet valve supply as the washer can deteriate or the old piping in the house can clog if they are old and made of galvanize pipe or the fill valve is clogged. replace valve and or fill valve in the tank
Aug 03, 2013 | Jacuzzi Home
The water won't whirlpool in the toilet
Usually when the water won't swirl it is because of a bad vent....a pipe may have sagged and filled with water blocking the air flow or the pipe maybe clogged with ice or something like that...
Sometimes the little holes in the toilet rim can get clogged with sediment also...
So check the toilet rim and make sure the toilet can get air trough the vent...
heatman101
Mar 07, 2011 | Home
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet is clogged . Plunging hasn't cleared the clog. Water drains quickly but don't get the gulp that all has flushed. What should I do other than take a sledge hammer to the Jacuzzi toilets and...
Pull the toilet up and look underneath it for a toy that got stuck. Also, look down the waste pipe for a toy that got stuck or for tampons.
Your not supposed to flush tampons down the toilet, because they are super absorbent and get stuck down the pipe, which inhibits waste flow. Especially the tampons with wings, cause they grip on the the side walls like the Dickens. You can rent a drain snake and send it down the waste pipe a few times to clear the clog. Make sure the bathroom vent is on and the windows open, because the smell is most disagreeable.
Alternatively, before going into this invasive procedure-you can go to Ace hardware and buy a bottle of Liquid Fire and pour it down the toilet to see if that clears things up. You can also order Liquid Fire online. This stuff dissolved a python rather quickly that had gotten into the waste pipe and clogged the thing up.
Cheers old chap.
Oct 10, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
2 tolilet bubbling (burping)
possible your vent is clogged .had very similar problem year's ago ,and it was an old house.check your vent pipe in attic, if it's galvanized pipe /steel,it could be full of rust .also access your vent pipe at roof , and run water via a garden hose to see what happen's. BE CAREFUL!!!!
Apr 14, 2010 | Home
What can I do to assure that my commode won't overflow? I came home after being away a week, and my basement was flooded due to the upstairs toilet leaking. Plumbers say it was just clogged. It totally...
Turn off the water at the valve going to the tank of the toilet. The valve is normally located half way between the tank and the floor, on a pipe leading to the tank. The water in the bowl will last over a week and should not be a problem. Good luck, I hope this helps Please rate me, Thanks
Dec 30, 2009 | Crane Plumbing Toilet To Go Tall...
Plumbing Logo
599 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
