Question about Plumbing
I have tried just about everything to clean the clog in my sink. Do you have any recommendations?
    Problem Solver:
  • 10 Answers
If you have exhausted all options like Drain-O and caustic soda I would suggest trying to snake the clock out. First try with a long wire; you can buy one at any hardware store. If you snake the wire around the pipes and can feel the clog but still can't push it out you will need to do something a little more drastic! Head back to the hardware store and buy a thin but sturdy rubber hose. I don't mean the kind for the garden. They should have something cheap that is just hollow rubber tube. Because this is more substantial, you should be able to push the clog out. If pushing alone doesn't work, find someone with pretty good lung capacity to try forcing it out with elbow grease and fast breath. Good luck!
Posted on Dec 26, 2013
Clogged pipes and drainage
if this is under your kitchen sink use a pail and undo the drain at the loop and clean out , if you dont want to get dirty try the compress air plungers
Oct 21, 2012 | Cobra Drill Snake Drain Clean, 25'
My HP 3116 TU laptop gets hot after using for few minutes as the exhaust is at the bottom. it may result in the crash of CPU or motherboard pls advice
Laptop heatup is mainly due the clogged heat sink and fan etc, which requires to be cleaned. It is strongly recommended that you clean the heat sink etc yourself or seek help from authorized profession at the earliest to avoid any damages to the PC.
Hope it helps! Do convey your feedback
CreativeTECH
Jan 13, 2011 | Computers & Internet
I have a whirlpool gold and there is water in the bottom after the cycle. i cleaned everything out and didn't see any blockage.
the drain hose maybe clogged it connects to the garbage disposal or the air gap at under the sink. you can get a wet dry vac and **** it out . or if the hose is just laying under the sink on the bottom of the cabinet you need a loop put in it. just attach it to the top of the sink some where and leave slack after the attached location toward the sink.
Nov 17, 2010 | Whirlpool DU930 Built-in Dishwasher
When running video or playing games fan seems to run loud the whole computer shuts off
That means the heat sink processor is clogged and needs to be cleaned. When the computer can't cool down the processor, it detects overheating and shutdowns to protect the processor.
The back of the computer needs to be removed and the heat sink needs to be cleaned. I do not recommend you to do it if you have no previous experience cleaning computers.
Dec 23, 2009 | HP Pavilion dv4000 Notebook
Our Badger garbage disposal is filled with water, won't empty out, just keeps running and spinning water around in the sink. We've tried the reset button, unplugging and plugging back in and a plunger. Any...
Sounds like the unit is fine but I think you have a plugged drain.Put an empty bucket under the trap and take it apart.Next remove the tailpiece from the disposal and clean it out.If everything is clean and you can't find the clog you will need a drain snake to remove the clog in the drain pipe.Good luck.
May 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Peerless sink plug is clogged with hair. How do I
The plug is held in place by a rod that connects to the plug lever. Look under the sink where this rod enters into the drain. The rod is held in place with a cap that is screwed onto the drain pipe. Unscrew the cap, pull out the rod, and the plug with then lift out.
On some sinks, the plug can be twisted to release it from the plunger rod, you simply twist it until it unhooks. It it does not twist, then folow the first set of directions
May 02, 2009 | Peerless Industries Home
Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Apr 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Clogged sink after using garbage disposal
You have a clogged trap. Try a plunger, draino or disconnect the trap and clean it
Mar 15, 2009 | Home
My kicthen sink is pulg up;
A power cable (snake) You can rent them or try a cheap hand cable snake one first..
Mar 14, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Plumbing Logo
892 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
