Question about EXPANSYS iTamTam
No sound from speakers
Product was working correctly then sound started to lose volume and disappear completely . Remote control is working and product is charging devices correctly
SPEAKERS DON'T WORK WHEN I PLUG THEM IN.
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 19, 2012 | Audio Players & Recorders
Speakers don't work
reinstall drivers
hope this helps
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps W7
I did some thing nd my speakers are not working
you might muted your sound or deleted the sound drivers
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Sep 28, 2011 | Logitech X-530 5.1 Speakers
No audio working
also
Sep 22, 2011 | Insignia 2.1 Speaker System (3-Piece)
I plugged in the Logitech Z4 speaker system, all the connections are on correctly but there is no power going to the speakers. Tried two different outlets, still no power. The power button is on. ...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jun 27, 2011 | Logitech Z4 Speakers
Well I just bought the Logitech ls21 2.1 speakers and subwoofer and I am having a few problems. A small problem is that I think something may be wrong with the wiring. The speaker output only works if I...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 19, 2011 | Logitech LS-21 2.1 Speakers
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
Two problem don't know if they're related. I'll sometimes get the dreaded loud POP and then no sound when playing from our cable box or Ipod, I'll lose sound on the speakers in the main room but I still...
I have the same two problems! "Zone 2" works, but the main amp will make a noise and then stop working. Sometimes when I change the listening modes around it will start working. Lately, though, "zone 1" has gone out altogether.
Jan 12, 2011 | Onkyo TX-SR603X Receiver
The speakers wont work no sound
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 10, 2010 | Logitech V20 Computer Speakers
Speakers are not working completly.
Please click on start /programs/accessories/entertainment/select volume control/click on the option windows default/thats all your problem will be solved.. thankyou...
Jan 02, 2008 | Altec Lansing MX5021 Computer Speakers
EXPANSYS iTamTam Logo
29 people viewed this question
Top EXPANSYS Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an EXPANSYS Audio Player and Recorder Expert? Answer questions, earn points and help others
