Question about Tablets & eReaders
Gemini g71 tablet won't start up
Started up before christmas but nowwonn't start up
How do i do a factory reset on my Gemini D7
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Apr 25, 2015 | Android Gemini Tab
My Gemini tablet has locked up and will not power down, is there anything I can do
there is usually a reset button somewhere on the unit, try that
Feb 09, 2015 | Android Gemini Tab
It crashes, won't turn on after resetting numerous times
Replace the battery delete apps you don't need and then reset
Jun 30, 2014 | Proscan 10.1-Inch Internet Tablet,...
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Apr 13, 2014 | Tablets & eReaders
My brand new Wolvol Android won't even turn on
I recommend you contacting the seller. They seem to have prompt service.
Dec 24, 2012 | Coco Android 2.1 Tablet (837121001186)
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
Tablets & eReaders Logo
18 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
