Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
This washer wont spin but it dose drian
The wont spin but it dose drain
    Scholar:
  • 85 Answers
Most likely your motor coupling is busted.
part number is 285753A
Posted on May 18, 2009
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
Washer washes but dose not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore 98702 Stacked Washer/Dryer
It dose not go to spin
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
Jun 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Wont spin, wont drain has codes
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore 80 series and it will not drain but it dose go to the next cyclr and it dose spin can you tell me what the problem is Thank You Ray
IT SOUNDS LIKE A DRAIN PUMP. THE PUMP PROBABLY HAS AN OBSTRUCTION (KIDS SMALL SOCK). PULL THE PUMP AND LOOK INSIDE IT
Oct 28, 2009 | Kenmore 24902 Top Load Washer
My washer wont drain but will spin in the spin cycle
That means that the water pump or the pump it self is going to go in it my washer did the same
thing we had to get a new pump or compressor. Dose it make a squeeky sound or a funny sound?
Mar 26, 2009 | Kenmore 24032\24036 Top Load Washer
I hear noise but the drum will not spin in spin cycle.
when you spin it by hand dose it feel free or restricted? if rstricted you may have a peice of clothing between the two tubs.if free you can have a worn clutch.but it would agaitate fine.if wont agaitate or spin it may be your drive coupler.and if the drive coupler failed your washer will still drain.if you need more help you can email me thru FixYa God bless ,tom
Jan 30, 2009 | Kenmore 24032\24036 Top Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
195 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
