Question about Poulan Pro " Pro" Self Propelled Mower
Have a Poulan Pro mower that won't start. When pressing primer gas is squirted into carb, but won't start. Tried starting fluid and it stsrts and runs for a couple seconds.
  • falinie May 24, 2009
    it is a new mower, I prime it and it will start but shuts off after a few seconds.
  • 10 Answers
SOURCE: Riding lawn mower problem
valves need adjusting.
Posted on Jun 01, 2009
AUTODOC01
  • 216 Answers
SOURCE: Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Posted on Aug 28, 2009
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My poulan pro GCV 160
Hi less4yourlea..
Remove your spark plug and check to be sure you are getting fire at the spark plug, if you are then:
Check your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on May 07, 2011
  • 32 Answers
SOURCE: I have a poulan 20"
Hi Sean,
Sounds like dirt in the carb.
Shut the gas off, or drain the tank, remove the carb bowl. There is a Jet in the stem of the carb where the fuel bowl screw was. you can blow air from a compressor up thru that and clean it out. also, clean out the screw that held the carb bowl on, there should be a couple small holes in it. Usually that will fix the problem, if not, then the carb would need to be taken off and rebuilt.
Posted on Sep 20, 2011
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Mower doesn't start
try spraying some starting fluid in carb if it starts rebuild carb
Jul 23, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Doesn't want to start and send pressure out of the carburator
Does your chainsaw have a primer button? Do you see gas moving in the primer bulb or hear gas squirting back into the fuel tank when you prime it? Ok...that part of the system is working...now.
See if it will start on a small splash of oil mixed gas placed directly down the carb. If it does, you probably have blockages in your carb and/or hardened/cracked carb diaphragms.
You can get rebuilt kits off of Ebay for a low price if you cannot find a kit locally.
Good luck and be careful.
Dec 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftman mower will not start
Hi there. I can help you. The problem is that your carbeurator is gummed up. You may have to remove the carb. and soak it in carb. cleaner for a few hours to get rid of the gum. However, I have often had luck with a fuel additive called seafoam and a carb. cleaner spray plus some starting fluid. Put the seafoam in your fuel using one ounce per gallon, then remove your air filter and squirt carb. cleaner in the air intake, two five second blasts. Try to start the mower. If it starts, great, if not let it sit for an hour while the carb. cleaner dissolves some of the gum. Try again ain an hour using more carb. cleaner and some starting fluid, a couple of blasts of each.
Jun 02, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro " Pro" Self Propelled Mower Logo
604 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
