Food in the refrigerator keep freezing .its v set at 38 degree
SOURCE: food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
SOURCE: my ge profile side by side refrigerator's
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
SOURCE: The refrigerator side of my Samsung RS2545SH is not cooling.
have the same issue......any ones fix this problem?
Hi Wha Young Kim, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
