Question about Pool & Spa
Hi this is john barnes from adelade ive got a herritageseater spa about 5 years old last year i put in a circuit board thats located under the spa its been workin fine and the control panel comes up as er6 and beeps you have to turn the spa off at the mains for a couple minutes then resets it self after awhile the spa comes up wth er6 it seems to happens abuot 35 degrees so i hope this will give you a better idear on whats happening and thankyou
    Top Expert:
  • Pool & Spa Master
  • 8,502 Answers
Possible bad temp sensor or motor overheating
Posted on Oct 30, 2017
nfandres
  • 168 Answers
SOURCE: T.V. COMES ON FOR 10 - 20 MINUTES THEN GOES OFF
well based on your story it seems that your tv when get hot loose some of its contact. i beleive the symptom is cause by a loose solder (cold solder). this is normal especially tv's that are aging. it tends to loose its contact because most of the parts/components of this device are becoming hot when being operated. example of this are resistors, transistors, and ic's(integrated circuits). check the power supply circuits and the horizontal deflection circuits. because these two circuits are responsible for problem you are experiencing. also use a magnifying glass in inspecting the board. based on my experience looking alone without this glass is not enough. you need to magnify it, to see it clearly. but if you are not inclined with this kind of job, better bring it to a qualified technician. one more thing, i dont beleive that the house is related with this problem. otherwise all your equipment that are hooked up in it will do the same problem (on and off). i hope this help you! good luck!
Posted on Feb 14, 2007
  • 42 Answers
SOURCE: Freezer won't defrost
savey73,
I think I know what is wrong. First the defrost thermostat you are talking about I believe is the round metal type with possibly a pink and an orange wire coming out of it. That is not the defrost thermostat as most people know it. That is a defrost overheat termination thermostat that opens only over 140 degrees F, that is why your old good one and your new good one show closed at room temp. If you read on the outside of the metal cover you will find it has a L140 indicating the limit of 140 deg.
Now to what should be causing your problem. You should find on the evaporator coil at the top left side of the evaporator coil a part that has 2 white wires going into what looks like about a 1" long X 1/4" round plastic thing. That little white plastic thing is a THERMISTOR. If it is bad your defrost will not work. Sounds like that is the only thing you have not replaced. There is no polarization of the wires That should FixYa
supertechks
Posted on Nov 24, 2007
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: main computer display panel Audio estate A6 5 years old
There is a button on the bottom of your windshield wiper control arm. Push it once to turn on or off the computer display. Hold it to clear the current information. At the end of the arm is a "up/down" button for changing which info you would like to see (miles to empty, current mpg, etc.)
Happy driving!
Posted on Sep 17, 2008
SOURCE: F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Posted on Dec 23, 2008
No picture
Most likely there is a picture, but you can't see it because the backlight circuit may have failed. Take a flashlight and shine it on the screen at different angles while closely observing the screen. If you can see a faint image operating there, then the backlight circuit has failed. It is either the inverter or the lamp. If the TV is more than 5 years old that is the most likely issue. Today's sets aren't as durable as the old CRT ones that lasted 15 years. 5-7 years without repair/replacement is the new norm. Until and unless manufacturers step up quality and durability, this won't change. Many folks on this site try to repair their machines by buying replacement boards and swapping them out in what we refer to as "easter-egging" to solve the problems. This usually results in either a failed repair or more problems since these devices are sensitive and easily broken. If the set is more than 5 years old, you are best served with getting a new one. And. remembering that the new one won't last much longer than that, don't overpay for the new one you buy.
Sep 20, 2015 | Televison & Video
I have Hayward H400IDL2 heater 6 years old. I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater
Hi, this is John the Hayward tech. If you are now seeing the #4 fuse go that is on the low voltage side. I would guess the main circuit board. I left a manual on your other post.
Aug 24, 2014 | Hayward Pool & Spa
I have a Sunbeam EM6910. The machine wont power up at all. Is my circuit board likely to be fried? It is 6 years old and perhaps not worth fixing?.
could be any number of faults but at 6 years old it is not economical to fix. How much did you pay and how many coffees in that 6 years... And what else did you learn....
Do some research and get a new system.
Jul 18, 2014 | Sunbeam Cafe EM6910
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
! year old, worked begining of wint. season. Now water on cover. No ice in hose, no noise from pump, have power at outlete. Last Rule lasted 3 years, this one 1 year. Is it time to look for an other...
Sorry to hear you are having trouble with the pump...Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
You may be interested in knowing they warranty the pumps for 3 years.
John
Dec 14, 2010 | Rule 1800 H53SP-24 Swimming Pool Cover...
No power on 8110 Intex Saltwater System
I have the same issue. Three years old so please do not say to send it in. Can you buy a replacement power supply?
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Intellitouch 9.3. Three years old, been fine till
I've been having the same problem - I don't have the complete solution but can tell you what I've been through so far. After 4 service calls and a visit from the local Pentair rep, they have replaced both circuit boards on the personality board. When they reconnected the spa-side remote, the electronics circuit tripped again. They are telling me I need to replace the spa-side remote, but I haven't since the repairs to date have cost me $1700 and they want another $700 to replace the spa-side remote. $2400 for a system that's 5 years old is ridiculous so for now I'm on hold, especially considering it may have been the spa-side remote all along. Don't know if your system includes the spa-side remote - if it does, disconnect it and see if the problem resolves itself, the remote may be the culprit.
Jun 13, 2010 | Pentair Intellitouch Pool or Spa...
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
