Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Won't dispense water from freezer door - ice maker works fine.
The light works when you depress the switch but I don't hear anything else.
    President:
  • 331 Answers
I'd wager that the water line inside the freezer door is frozen keeping water from flowing.
Here's how to test my theory; Open up both doors and remove the "kick panel" (it's just snapped into place, so just pull on it). After that's done, look below the bottom freezer door hinge... you'll see the water tube there. Now, about 4" to the right of the hinge, you'll see a tubing coupler there. Disconnect (unscrew) it. OK, now just reach up there and depress the chilled water dispenser (like your gonna fill a glass). Did water come out of the tube near the floor? If so... the tube in the door is frozen.
The only fix for this is to completely defrost the fridge. (As in, unplug it for at least 24 hours) The reason is because there is no way to access the tube in the door... it's "foamed" in place and not serviceable.
I've heard of a trick you can employ after it de-ices to keep it from happening again. (Note, that I've never used this trick, but heard that it works, OK?) Alrighty then... when it's completely thawed and water is flowing like it should, cut yourself a piece of plastic cord (like weed-eater string but small) about 18"-24" long. Then you take this cord and feed it through the tube where the chilled water comes out of the dispenser. Feed it down the tube almost all the way leaving about an inch or so hanging out of the water dispenser.
OK... here's what is supposed to happen; If it ever freezes shut again, all you have to do is pull that string outta there. This will allow water to flow again. Then all you have to do is grab a huge cup (like a "big gulp") and fill it up. The water flowing through there will thaw out the frozen stuff and clear the line. After it runs free and clear again, just replace the cord and wait for it to freeze again.
Hope this helps! Let me know by rating this solution as "it solved my problem", will ya? Thanks!
SG
Posted on May 17, 2009
Ice maker, water and light stopped working.
If the light you are talking about is the freezer light, along with the ice maker and and water dispenser, I would guess you have a bad freezer door switch. That switch works the light but is also an interlock switch that keeps the dispenser features from working when the door is opened. Either the switch is bad or a wiring problem going to the switch.
Apr 07, 2015 | Refrigerators
Ice maker works fine and ice comes down but when it goes to crush the ice it wont crush it jams up
Remove the ice bin, examine the metal arm on the back of the bin. This arm needs to move up and down freely, this arm is the shifter for the cube and crush setting. Also look at the square hole in the back of the freezer where the bucket came out of, the shifter in there needs to be down all the way also.
With the freezer door open, depress the cube setting on the door, hold the light switch and depress the dispenser button, do you hear a click? If so the shifter works in the freezer and the problem in in the bin itself. With no model number given, I have to assume the ice bin is not in the door, its inside the top portion of the freezer section.
Good Luck
Nov 05, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water is not coming out of water dispenser
Hi and welcome to FixYa,
There are 40 models under this main grouping: KSRG25FK I had to pick one....
KSRG25FKT05 as an example:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906
Listen for the micro switch item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906&diagram_id=28177830#d28177830
You should hear a click as you actuate the water dispensor arm. (no click = bad switch)
Note also that the freezer door must be closed. Check the freezer door switch item 25 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504906&diagram_id=28179767#d28179767 The light should go off when the plunger is depressed. If the light says on with the plunger depressed the switch has failed.
FYI you would have no ice in door if this switch has failed. If the ice in door works and there is only a water in door problem disregard this step.
Last open the fiberboard cover in the back of the unit and locate the inlet water valve. If you can do a swap of the 2 solenoid connectors between the 2 solenoids. Then use the water in door actuator. If you get water to the icemaker with the freezer door light switch plunger depressed you have a failed water in door solenoid on the inlet water valve. The water inlet valve is NOT repairable.
This is a KIT for replacing the inlet water valve:
http://www.appliancepartspros.com/part_details.aspx?part_id=3160649
You can find the valve cheaper without the kit parts if you shop around.
This is a Job Aid that will show you how to open the dispenser area if you need to.
http://applianceassistant.com/pdf/inDoorIceSystem.pdf Also good for ice maker and water in door troubleshooting.
Thanks for choosing FixYa,
Kelly
May 10, 2011 | KitchenAid Superba KSRG25FK Side by Side...
My water dispenser will not work but the ice maker works fine. What should I do?
You have a dual valve in the back, one is for the ice maker the other is for the water dispenser. There is a small micro switch being depressed when you push the lever, this closes the circuit and 120 volts to the valve for water to flow. That is basic technical stuff. You need to check for power at the valve when the switch is depressed. (If you hear a buzz you generally have the power, and your valve is bad or the line is frozen in the back of the refrigerator section where the plastic coil loop is or froze in the freezer door itself .
Unhook the line at the valve on the side you are testing or at the bottom of the door to isolate these things. Do not try to test too many things at once and keep the kids away......
Jan 19, 2010 | Kenmore Refrigerators
No water comes out from dispenser but the ice maker works fine.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Nov 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Dispensing Problem
Oct 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser stop working? ice maker is fine. How do you fix this? I changed the water filter hmmm..
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there it’s a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 08, 2009 | Jenn-Air JFC2089HE French Door...
Ice maker works on Kenmore side-by-side but will not dispense
If there is ice in the bin and you hear the auger motor running when depressing switch then the auger is broke or the ice bin is busted , pull the bin out and empty it and de ice it to inspect for cracks. you can also turn the auger/fork in the freezer and it should turn the motor and have some resistance when turning. let me know if you have any other questions.
Phil
Apr 11, 2009 | Refrigerators
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
296 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
