Question about Samsung 26 Cu. Ft. Side-by-Side Refrigerator, RS267LA
The refrigerator portion has quit cooling.
Our Samsung RS267LASH Side by Side Refrigerator is having problems. The refrigerator portion has quit cooling. It will only cool down to 60 degrees. The freezer portion is still working. We paid a repairman $400.00 for a new motherboard. That did not fix the problem. The refrigerator has now been broken three weeks and the repairman does not know how to correct it.
  • tinkerfeet May 25, 2009
    Same thing with mine.
    New Friend:
If you remove the drawers you'll probably see that the back of the fridge is bowing in somewhat. That is because the heater element that defrosts your fridge coils has failed and those coils are completely iced up. It is now all iced up and will not cool. If it made a weird noise for a couple of weeks that was the fan rubbing against the built-up ice. You need to get that heater element replaced. Happened to ours on Thanksgiving day. The tech used a blow dryer to remove the built up ice and replaced the heater element. Works fine again, although today my water dispenser quit dispensing water. ALL of the fridges are using cheap components these days... the techs will tell you it doesn't matter what brand you buy.
Posted on Dec 23, 2012
    Problem Solver:
I have the same problem and have found that if you take the panel off inside the refrigerator and with a blow dryer defrost it. It should work for a few weeks. I have been doing this once a month since March and I hope to found out how to fix it also.
Posted on May 18, 2009
  • Wilson Bradley Aug 28, 2010
    Manny MANY unfortunate customers who bought this **** from Samsung have this problem . It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Refrigerator side only cooling to 60 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator temperture is about 60 degrees. freezer 30 degrees and tehre is ice builu up on the back wall of the freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 13, 2011 | Jenn-Air JCD2290HES Side by Side...
Refrigerator side won't go lower than 60 degrees. freezer side is okay.model FRS26ZTH04
heatman101
Dec 15, 2010 | Frigidaire FRS266ZDSB Side by Side...
Freezer works but fridge doesn't stay cold
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
My freezer remains cold at the proper temperature however the refrigerator is about 60 degrees. The fan is working in side the refrigerator. Sumsung Model# RS267LASH
That is way too warm for a refrigerator, those temps are unafe to keep food - it should be no warmer than 40F, and optimally 34F. For your freezer no warmer than 10F, optimal is 0F and colder.
If your freezer is within those temps, then your evap fan is working normally - you might want to have your damper checked - it is a flap that opens and closes as needed to circulate cold air to your refrigerator - if this damper is stuck and woN't open or open wide enough your refrigerator won't get the needed cooling.
You might want to check for leaky gaskets in your door.
Sep 03, 2009 | Samsung Refrigerators
Model #RS267LASH fridge is not cooling but freezer side is. What could be the problem with this Samsung? Thanks,
If your RS267LASH refridgerator is not cooling it is because it is not defrosting. In order to fix it they will have to take it into the shop to cut into the copper wiring, remove the freon and change out the probe inside. The parts and labor are covered under warranty for 5 years. This was the last thing done to mine after changing out the board, a fan, and a thermocouple.
Jul 12, 2009 | Samsung Refrigerators
Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Mar 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
806 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
