Question about HP Vectra VL400 P3 Skt 370 Motherboard D9820-60009
Lan connection! Vectra VL400, D9820-60009. No connection with LAN cable.System:Windows XP (family). It doe's connect with UBS wireless card. Is it because the motherboard doe's not detect the connection?
  • 221 Answers
Is the lan port on the motherboard?
if yes, is the lan port turned on in the BIOS?
Does XP detect the port?
If no, check if BIOS setting is on.
Posted on May 18, 2009
So I just got a Dell Optiplex sx280 that runs windows xp and can't connect it to the wireless internet at my house. The built-in driver is a Broadcom NetXtreme 57xx Gigabit Controller, and I don't...
Desktop computers do not usually have a wireless card installed. They will have a built-in LAN card that uses a LAN cable.
If you want to connect your computer using a wireless connection then you will need to install a wireless card in your computer and configure it to communicate with your wireless router.
Otherwise you can connect to your wireless router using a LAN cable.
Your wireless router may have built-in LAN ports and you can connect your computer to the wireless router using a network cable.
Jun 09, 2011 | Dell OptiPlex SX280 PC Desktop
I bought a acer travelmate 220 How do I use it wireless do i need a card and router
hi
    Instructions
  1. Step 1 Navigate to Acer's support and driver download website at support.acer.com/drivers_download.aspx.
  2. Step 2 Choose "notebook" from the "Product family" list.
  3. Step 3 Select your product line (Aspire, Travelmate, etc.).
  4. Step 4 Select your model number to identify the exact machine you own.
  5. Step 5 Scroll down the "Wireless LAN" entry, under the "Driver" tab.
  6. Step 6 Click the yellow "Download" button located to the left of the "Wireless LAN" entry.
  7. Step 7 Open the installation file once the driver has finished downloading.
  8. Step 8 Follow the on-screen directions to install the wireless driver.
  9. Step 9 Restart your computer when prompted to do so by the driver installer. This will finalize the installation process.
  10. Step 10 Attempt to connect to a wireless network.
Jul 07, 2010 | Acer TravelMate 240 Notebook
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
XP Keeps rebooting with LAN Cable connected
Have you tried going into the bios setup before windows loads up? You may have a setting to choose startup on lan. Just turn that off and hit F10 and enter.
To enter the bios setup keep pressing delete after truning on the computer until the bios screen appears. Don`t change anything unless you know what you are doing.
May 14, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
May 15, 2008 | Samsung X05 Notebook
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Wired LAN
A usb ethernet adapter does not cost much and no troubleshooting needed.
I assume your trying to get your built-in card to trigger have you checked the bios to be certain it is enabled.
and go to control panel check the system device manager to see what it says about the ethernet.
does it show up under my network places and if it does is it bridged. Get properties on it.
Jan 29, 2008 | Acer TravelMate C100 Notebook
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
HP Vectra VL400 P3 Skt 370 Motherboard D9820-60009 Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
