Question about Samsung Heating & Cooling
Display Shows wrong temperature
The temperature is set to 16?C but the display jumps to 66 while the thermometer in the room says its 29?C
  • 90 Answers
It is your remote set on grade celsius?
Posted on Dec 27, 2013
  • Tunji Mesh
    Tunji Mesh Dec 27, 2013
    Yes it is. It shows the temperature in centigrade when any function button is pushed, but changes back once its idle.
  • 8 Answers
SOURCE: furnace-not heating all rooms to set temperature
Depending on where your living room is in comparison to your furnace it could be just that the fan doesn’t have enough force to get it there so what is happing is that all the other air is reaching other rooms before it. There are products that can help with this u can find them at larger hardware stores they r inline fans that go in the ductwork or there r a flat type of fan that mounts on the vent and plugs into a wall outlet that will pull the air to that room the latter would be much easier but it is your choice. Hope this helps.
Posted on Nov 08, 2007
SOURCE: temperture bulb
i called the tec support at rinnai.
Posted on Oct 07, 2008
electrodynam
  • 35 Answers
SOURCE: thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Posted on Mar 19, 2009
bobicehouse
  • 1524 Answers
SOURCE: NEC RIH 2667
Circuit board
Posted on Apr 23, 2009
darjr
  • 378 Answers
SOURCE: Aircon problem
check the filters maybe its full of dirt.
Posted on Jun 07, 2009
Heater set on 100 display shows 126
Obviously one (or both) is/are wrong. The easiest way to figure out which is to use a thermometer to take the water temperature to determine to actual temperature. Then you can decide whether or not to spend money to repair indicators or thermostats.
Sep 07, 2016 | Pool & Spa
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
Freezer temp display shows 53 but inside it is 8. What could the problem be?
Either the pickup sensor for the thermometer is dislodged, in the wrong place, or the thermometer is defective. It's great that you checked it with another thermometer. The freezer should be in the temperature range you reported....good work.
Dec 06, 2009 | Samsung RS2534 Side by Side Refrigerator
HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Jun 10, 2009 | Haier Heating & Cooling
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Maverick et 72 remote thermometer when it is turned on it reads HHH
If the receiver and/or the transmitter display LLL or HHH instead of the probe temperature,
wait for probe to reach room temperature. If LLL or HHH is still displayed it is likely the
internal probe wire has shorted out either through moisture or heat damage.
-Tha Mp3 Doctor
Nov 27, 2008 | Maverick Wireless Remote Smoker...
Over heat
whats the room temperature ?the room temperature may effect the systems temperature,again the processor usage,or the particular heat sink attached to the processor if it dosnt dissipate much heat and instead circulate within can cause high temp so check that out
Jul 16, 2008 | Intel DG31PR Motherboard
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Heating & Cooling Logo
124 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
