Question about Honda Silver Wing 600 2005 Factory Evoii Full System Exhaust With T
ABS LIGHT FLASH LIGHT OF ABS MARKED CODE 11 &51
  • 35 Answers
Check conector wire
Posted on Mar 23, 2014
Need abs code 9 solution for 1995 Toyota Avalon XLS
old car, and old ABS,
no FSM,
no alldata.com
no looking first at Toyota nation dot com>?
they are 2 digit flash codes.
95-98 is same
look it up here.
http://www.wellsve.com/custom_searches/abs_troublecodes.php?make=Toyota&model=Avalon&year=1996&code=39&submit.x=58&submit.y=28&confirm=1
above link is demo of code 39
Jul 18, 2014 | 1995 Toyota Avalon
Abs light stays on and is flashing a i think acode
hi Robert
you can check the ABS fault code as following:
switch ignition on and wait for the abs light to start to flash.
it will flash in long and short flashes, long flash stands for ten, short flash stands for one, there is a short pause in between, and long pause after each code, take a note of the code and Google it
good luck
CODE 12 CODE 21
Jan 17, 2014 | 1993 Ford Ranger SuperCab
ABS C1286
A vacuum leak to booster, a bad booster and last bad switch at brake pedal, again dealer must do control module calibration or light will flash indicating calibration is needed.
Sep 03, 2012 | 2000 Jaguar S-Type
When using a jumper wire to retrieve ABS trouble codes on a 2002 Trooper 4 wheel drive how is the DLC numbered? I mean which pins do I jump? And when I do jump, Will the ABS light flash te codes....
ok, there are 16 pins in the DLC you want to jump #4 and #12 as you look at the connector from left to right top row is 1-8 bottom row from left to right 9-16, both rows the 4th pin jump them together. then count the flashes all codes are 2 diget ( example flash-flash pause flash-flash = code 22 )
Feb 17, 2011 | 2002 Isuzu Trooper
I have a 2004 chevy aveo ls the abs light is on and sometimes it acts like it dont have brake any answers out there thanks
you need to have the abs computer scanned for trouble codes . i think that auto zone or advanced auto will scan it for free
Jul 11, 2010 | 2004 Chevrolet Aveo
The left turn signal stopped working, then the right. Now the blower and the abs light is on. I changed the turn signal switch/hazzerd/wipers. And the 10 amp fuse keeps blowing. Marked turn/bu/abs
20amp turn on four ways and parking lights go around replace any bad bulbs turn of for ways tern key on tern right tern on go around se if blinking tern on left and se if not chang flash thears 2 flashers switch the tow to se witch is bade.chek fuse for the right amp look inside fuse cover for right amp
Jan 26, 2010 | 2000 Dodge Caravan
ABS light goes on and off
Sounds like you have loose brake pad linings.
The traction control measures rotational speed between each rear wheel. If your pad lining momentarily causes one wheel to hesitate your trac control will flash. As the ABS detects braking without the brake pedal being pushed, it will flash.
Check your emergency brake pads. They can fall apart inside the drum/rotor combo on the rear. That is where your sensor is for the ABS.
Aug 15, 2009 | 2003 Ford Mustang
Abs light blinks 16 times brake lights dont work
16 is a pass code. For some reasom your diagnostic connector is in test mode.
If light flashes, diagnostic circuit is grounded. CORRECT condition.
If anything other than Code 16, and starting with the first code recorded, GO to the pinpoint test for that code.
If Code 16, and if previous action has been taken, concern most likely has been corrected and ABS system is OK. Otherwise, GO to PC6 .
Diagnostic Data Link Connector located at the left-hand side of the engine compartment and marked ANTI-LOCK TEST.
Jun 26, 2009 | 1996 Ford F350 Crew Cab
ABS light
It is picking up a signal from one of the wheel sensors probably.
Go here to read files on ABS issues
http://autos.groups.yahoo.com/group/villagerquest/
  • Anti-Lock Brake Warning Indicator Always On
  • Fuse(s).
  • Circuit.
  • Hydraulic solenoid relay.
  • Hydraulic pump motor relay.
  • Brake anti-lock sensor(s).
  • Hydraulic anti-lock actuator assembly.
  • Anti-lock brake control module.
  • GO to ABS Quick Test .
QT5 PERFORM ABS TROUBLE CODE RETRIEVAL
  • Key OFF.
  • Jump Pin 4 of the data link connector to ground.
  • Key ON.
  • Observe the anti-lock brake warning indicator.
NOTE: The first code to flash will be the start code (12). Also, each code is repeated three times before proceeding to the next trouble code.
Does the anti-lock brake warning indicator flash codes? Yes No RECORD code(s). GO to the following ABS Trouble Code Identification Chart in this section and PERFORM Pinpoint Test specified for first code retrieved. If indicator is illuminated constantly, GO to Pinpoint Test D1 . If indicator is not illuminated, GO to Pinpoint Test A1 .
Jan 02, 2009 | 1993 Mercury Villager
Abs light on, cruise control and engine light 2007 subaru outback
55 EGR Temperature Sensor or Circuit
ABS light is nothing to do with code 55 separate fault circuits.
Under dash there are two wires with mini spades at the end, connect one of them to the single black multiplug in position 2. Thats RHS plug inlet when you hold plug with tab lock on top.
ABS sensor should then flash up error coded. Ignore code 11 thats a initial flash to let you nknow the difference between a fast and slow flash.
Let me know what code flashes up and I will tell you the symptom,
Dan
Jan 01, 2009 | 2002 Subaru Outback
Honda Silver Wing 600 2005 Factory Evoii Full System Exhaust With T Logo
Top LeoVince Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a LeoVince Vehicle Part and Accessory Expert? Answer questions, earn points and help others
