Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch s16p1f blowing fuse
Runs for 5mins blows rcd
3 Suggested Answers
  • 51 Answers
SOURCE: Bosch Dishwasher classixx blows fuse when turned on
No don't hose it out. That will only make things worse. There are a good number of reasons why it may be blowing the breaker. You will need to meter out the different parts to check for a short. My guess from you description is that the softner unit has broken / leaked and gone into the main pump. You will need to replace both if thats the case.
Posted on Jul 25, 2007
hunter19_46m
  • 7482 Answers
SOURCE: bosch exxcel slimline dishwasher keeps blowing fuses
Hi david parker...
Check to make sure your motor is not binding up and also check your swing arms inside of the dish washer to make sure they are not bound up also.If not bound up then try to run the motor by itself to see if the motor is good...if the motor runs then replace the switch
Please rate me
Bud
Posted on Sep 27, 2012
Machine displaying general alarm the infuser slide was very tight freed up and reassembled now turning the machine on results in an arc at the motor brushes which blows the RCD breaker.
Hi Chris
Good Job freeing it all up etc. Your 90% there
Can you remove brushes & clean and stretch a millimetre more out of brush leads to stop arcing. Or perhaps the load is to great.
I did notice you said RCD.
RCD's usually only trip when an in-balance occurs between the hot phase wire & neutral wires.
Eg... what goes in via phase wire must come out on neutral wire. Even a small millivolt trickle to ground will trip an RCD. (20-30ma)
The Residual Current Device is for electric shock Safety.
It is not the main fuse or circuit breaker.
RCD's can be a real pain when there is a slight moisture leak.
For Example.
My fridge in my Winnebago would trip the RCD after it hadn't been used for awhile. The insulation around the 10A heating element was damp & tripping the RCD continually.
So how do I bypass the RCD to heat the element up and get rid of moisture. My method was to use a stand alone generator with no RCD to power the RV.
Worked great. Once the element surroundings were dry it ran fine on the home 240vAC.
So... If you really are tripping the RCD then the problem is AC "LEAKING" to Earth. Usually Moisture.....Try a hair dryer
If it is really blowing a Fuse or Circuit Breaker then the problem is too much current being drawn in circuit.
Hope this Helps
Trevor
Apr 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Mains RCD blows after a few minutes of operation
You have a short inside the control unit. When it opens the power protection disengages the unit. It is a warning to get it replaced or face the possibility of a house fire.
Feb 26, 2014 | Miele G 1182 SCVi 24 in Builtin Dishwasher
My house fuse box is fitted with a master RCD. A feed off a lounge socket goes threw the wall and feeds an external weather proof RCD box which when switched supplies my garden lights. If a garden light...
Appears the main box RCD is just as fast as the secondary RCD and it sensed the same fault that triggered the outside unit and it didn't wait around to see if that outside unit did the job.
Sep 07, 2013 | Kitchen Ranges
Bosch exxcel slimline dishwasher keeps blowing fuses
Hi david parker...
Please rate me
Bud
Sep 26, 2012 | Bosch Dishwashers
I have a Bosch Classixx slimline dishwasher. I completes most of the cylcle but trips out the electricsnear the end of the cycle - probably the drying cycle - any ideas Garry
Hello Garry,
I suspect the element in the water heater is either burning out or shorting to earth. If it's burning out, the increased resistance will cause an overload and trip the breaker or blow the fuse for that circuit. If it's shorting to earth, it may trip both the breaker and the RCD in your fuse box / consumer unit.
Next time it happens, check whether the RCD switch (assuming you have one) is in the 'OFF' position. Most breaker boxes will be fitted with an RCD which protects many, or all, of the individual circuits. It's easily identified by the presence of a 'TEST' button.
That's only going to be a clue to the likely cause of the fault though. You really need to do some testing of the element with an ammeter and/or multi-meter, if you have one. I can provide instructions for testing if you have the equipment and inclination.
Unfortunately, if it is the water heater, the cost of a replacement is about £100 for the part alone, for the SGS43C12. Water heaters for most other Bosch models are roughly the same price and some of the older models can be £130+. If you need to get someone in to fit it, you could be looking at a total bill of between £150-200. Considering the age of the SGS43C12 / Classixx, it may be time to consider replacing the dishwasher.
Obviously, I'm assuming it's the water heater as this is the most likely cause, but there are other possible faults. If you need any instructions on testing, etc, please confirm the correct model number as the SGS43C12 isn't a slimline model.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Oct 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Our hotpoint ctd40 condenser dryer aquarius trips our household rcd panel when you try to start the machine all the power lights are on and it does not blow the plug fuse. I have cleaned all the filters...
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Feb 04, 2011 | Hotpoint Dryers
My whirlpool dryer keeps blowing the fuse for heating. The dryer will still tumble but once stopped, won't start until the fuse is replaced. We've cleaned the whole thing out and even set up a different...
I would check the outlet as it sounds like one of the wires is off/shorted. Here is a website that may assist you, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 01, 2010 | Kenmore 63932 Electric Dryer
My GS28v00GB001 upright freezer trips my RCD. I've replaced nearly every electrial component (capacitor) Starter device, Sensors and still it does it. Initially it runs for a number of hours till it trips,...
I am not familiar with Bosch but I do know that other brands use the defrost heater as a source for power to the compressor while running. If the heater is partially grounded it could cause this problem. If this is okay have your thought that maybe your RCD is going bad... just a thought
Apr 24, 2010 | Bosch Freezers
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Jul 20, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
62 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
