Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Got a problem with my hard drive. I got my hard disk partitioned a while ago. Its 180GB. There are no heavy files on the drive but it keeps popping up the message of low disk space. When i checked the properties, it shows only 50mb available. When i browse thru the folders, i see no files that maybe taking up that much space. Pls help. I m worried my laptop might crash. M using sony viao with windows 7 64 bit. Thanks..!
    Problem Solver:
  • 5 Answers
Most likely to be either the waste basket not being emptied for a user, or it could be the system restore where old restore points exist. In windows explorer, right click the disk and select 'disk cleanup' Give that a go.
Posted on Dec 26, 2013
jimmynuetron
  • 24 Answers
SOURCE: Low hard drive memory due to invisible files using 90% of available space (apparently?)
Just found this it seems you do not need any tools to resize check this out..
lifehacker.com
Screen shots
lifehacker.com/
Posted on Nov 11, 2007
Jastababe
  • 117 Answers
SOURCE: not able to delete partition in hard drive
This will be in a few steps..pleas follow carefully.
l
To delete a partition or logical drive • Using the Windows interface if(typeof(IsPrinterFriendly) != "undefined") { var l = "#BKMK_WINUI"; var nl; var c = l.charAt(0); var o = document.getElementById("EO"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; }
Using a command line if(typeof(IsPrinterFriendly) != "undefined") { var l = "#BKMK_CMD"; var nl; var c = l.charAt(0); var o = document.getElementById("EU"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; }
Using the Windows interface 1.
Open Computer Management (Local).
2.
In the console tree, click Computer Management (Local), click Storage, and then click Disk Management.
3.
Right-click the partition, logical drive, or basic volume you want to delete, and then click Delete Partition.
If the menu item reads Delete Volume instead of Delete Partition, the volume is a dynamic volume. For instructions on how to delete a dynamic volume, see Related Topics.
Caution
• When you delete a partition, all data on that deleted partition or logical drive is lost.
• You cannot recover deleted partitions or logical drives.
Notes
• To perform this procedure on a local computer, you must be a member of the Backup Operators group or Administrators group on the local computer, or you must have been delegated the appropriate authority. To perform this procedure remotely, you must be a member of the Backup Operators group or Administrators group on the remote computer. If the computer is joined to a domain, members of the Domain Admins group might be able to perform this procedure. As a security best practice, consider using Run as to perform this procedure. For more information, see Default local groups if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/f6e01e51-14ea-48f4-97fc-5288a9a4a9b11033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EKC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } , Default groups if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/1631acad-ef34-4f77-9c2e-94a62f8846cf1033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EPC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } , and Using Run as if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/8782f8ab-9538-4111-8a68-7bfd130c21c01033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EUC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } .
• To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
• You cannot delete the system volume, boot volume, or any volume that contains the active paging file or crash dump (memory dump), or OEM partition.
• You cannot delete an extended partition unless the extended partition is empty.
All the logical drives in an extended partition be deleted before you can delete the extended partition.
Posted on Mar 01, 2008
leecom72
  • 4806 Answers
SOURCE: Where is the /System32 folder physically located on the drive?
Hi there.
This is the path >>>>>> c:/windows/system32....
So, click on "my computer", you will see "local disk c", click on that, if it says "these folders are hidden" click on "show files". Then click on the "windows" folder, in that folder you will find "system32" folder.
Thanks for choosing FixYa!!
Posted on Jun 12, 2009
JaxPlanet
  • 922 Answers
SOURCE: How can I mount an IBM AIX hard drive in Windows?
AIX uses a file system that is not supported by Microsoft Windows. Most likely you will need another AIX system to read the file system. I recommend that you contact a hard drive recovery service like Ontrack Data Recovery and get some guidance.
You should remove it from the Windows computer ASAP. Windows has the habit of making changes to any disk it sees and you may lose everything!
I hope this helps.
Posted on Jul 24, 2009
ACinfoTech
SOURCE: what is pc health
Pc health is a new virus. I am trying to disable it. try renaming the files in the folder with a right click or some other way if the other tries do not work. Also change the folder options by first making the PCHEALTH folder read only and then making it all not read only.
you will have to delete the User and Software registry keys after reinstalling windows.
Posted on Aug 08, 2009
How to solve low disk space warning on my Windows 7 laptop?
It sounds like you have too much running in the start menu. If you go there you have to be careful what you stop from loading. Go to your start and left click. The search box at the bottom type msconfig Go to the startup tab. Anything like Adobe reader, Java, any toolbars, quicktime, realplayer or anything that doesn't need to start when you boot the computer uncheck the box on the left beside it. When you click apply and ok it will ask you to restart the computer. After you do a box will popup and you can check the box and click and you won't see it again. But like I said you can stop the wrong things there. If you don't feel comfortable trying it get someone you know who is tech savvy to help you. Anything Microsoft, Intel, or with your computer brand name needs to stay.
Dec 10, 2014 | Toshiba Computers & Internet
I have got a big problem for my wdc wd6400aaks hard disk. Few months ago i separated hard disk into 4 partition (named as DATA, Install, Slave and Local disk). But XP2 had auto numbered my partitions and...
no no you need only slave c your sata only f drive is a out side hard drive e is your sec cd dvd player d is is your floppy disc ran off you slave mane cd player ok here what your going to have to do reset everything in fresh formate with your reboot disc.
Feb 13, 2011 | Western Digital Computers & Internet
Hi, Thanks for using fixya.
Right click on My Computer/Computer choose manage. On the left side make sure storage is expanded double click disk management, on the lower part find your Drive you want to change right click on it choose change drive letter and paths. Click on change, You will see a drop down arrow click that choose the first available letter, Now click on change. Do this to all of the drives you want to change Open My Computer/Computer see if it is now listed the way rou want it.
Ps you can't change the c drive if it is used as the operating system storage.
Terry
Feb 13, 2011 | Gateway (M520HD80G) Hard Drive
I need to change my default Download driver to the D drive as my C drive is always full, I've tried to move some of the programs from the C drive to the D drive but it says that some of the files may not...
Try the disk cleanup in the disk properties (right click the disk icon).
You can really free up a lot of space by deleting temp files, memory dump files and all restore point but the last. The last thing you only want to do if your system is running stable of course.
Also make sure to defrag after disk cleanup to maximize the efficient use of the free space.
Dec 14, 2009 | Lenovo IdeaPad Y510 Notebook
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Computer keeps freezing and losing work i have
Happens to the best of us, buddy. In time with, miscellaneous program installs making minor tweaks to system files here and there, the ol girl is bound to get cluttered. Your best option is to do a quick Time Machine backup which will back up all your documents and personal items, then pop in your leopard disk to do a quick reinstall. Your computer will be shiny and like new :) Boot from the disk. When it comes up select the disk utility from the menu bar and partition the hard drive to 1 partition and take the default settings (but name the partition whatever you want, this is where you would type Hard Disk if you want it to remain titled that). Continue on the install leopard path, and when it's all done and you're logged in, fire up Time Machine and restore your stuff.
Grab a beer and enjoy your fresh install :)
Jul 15, 2009 | Apple MacBook Pro PC Notebook
Missing GB after unpartitioning hard drive
please goto start>control panel>Administrative Tools>Computer Management>storage>disk management . Here you will find all unallocated space and allocateds too. please make those unallocated spaces new partition.
surely it will help you.
Rate me if it helps
Apr 18, 2009 | Maxtor Hard Drive
My computer don't use the all Hard Disk memory
You can resize the partition with a program called Gparted. You can download it here: http://sourceforge.net/project/showfiles.php?group_id=115843&package_id=271779
Download the .ISO file and burn it to a disk as an Image. Boot from the disk at startup and follow the instructions to resize your partition. Gparted is a very easy program to use so you shouldn't have any problems.
Mar 11, 2009 | HP Compaq 6830s Laptop
Partition inaccessibIe - iOGear COMBO ION GHD135C120 Hard Drive
Hi there. you may try changing the drive letter by going to disk management. Right click "my computer"icon and select manage. Go to Disk Management. check the size of the drive you're having problem with. If it still shows that there are files saved, right click the drive letter you're having problem with. Change the drive letter to Y. Try accessing after.
Mar 06, 2009 | IOGear COMBO ION GHD135C120 120 GB Hard...
Acomdata external hard drive
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
