Question about Kenmore 43042 Front Load Washer
Kenmore Front load Belt problem
I have Kenmore fron loader 4174415 2400 and now at the time of spin the belt come off and igitater wheel become loose.
  • 91 Answers
Can your retighten it ,,w / cresent wrench if not bearing is probably shot check for any leaks
Posted on Jan 04, 2009
How do I get to the belt moter on a sears Kenmore 500 cloths dryer the belt is off but not broken
The usual method of accessing the belt is to remove the entire fron panel (including door). It is usually easy to remove the panel by removing a couple of screws at the top and pulling up and out on the panel. The belt can be reached from the front. All dryer belts have a spring loaded tensioner on the belt. Check the tensioner as belts hardly ever come off unless the tensioner spring breaks.
Oct 20, 2014 | Kenmore Dryers
Candy go1482
please follow this steps for problem spinning.God bless you
  • Is the belt broken? Loose?
  • Does the lid switch click when closing?
  • Does the spin solenoid engage?
  • drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • clutch worn out?
  • Current to motor? (Use voltmeter to check)
May 28, 2013 | Washing Machines
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
The spin cycle is very slow. how do i tighten the belt?
there is no adjustment that can be made.either your motor windings are weak and causing the tub to spin slowly.or the transmission bearings are going out causeing extra tension and slowing it down.
you could have a bad belt as well over time they do get a little stretched and become loose on the pulleys.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore h3 won't spin
Remove the pulley nut and pulley. The pulley should have a round hole with two flat sides that ride on a shaft. If the flat sides of this opening are damaged the pulley will not stay tight and will rattle. Try tightening everything down. If you can grab the pulley (like a steering wheel on a car) and turn it back and forth on the shaft, there shouldn't be any "play" in it. The whole drum should turn. If this is the case, replace the pulley and nut. I hope this helps you.
Jul 31, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43042 Front Load Washer Logo
148 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
