Question about Samsung Televison & Video
La40B650 Colour distortion
My screen has lost colour and is distorted. Can it be fixed?
You will need a real technical person to diagnose this by taking it apart to check the circuits. There should be some adjusting screws on the circuit boards for distortion and color control.
Dec 21, 2014 | Televison & Video
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Samsung LCD TV colour distortion
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung Televison & Video
Projectors colour is purple how do i fix
Most single color distortions are caused by a bad vga cable, does it distort upon startup or only when a certain device is attached?
Oct 22, 2010 | Hitachi CP-S225 Multimedia Projector
Colour Distortion
I got the same problem, all you have to do is turn off the laptop on the back of the laptop & switch it back on
Feb 12, 2010 | HP Pavilion dv6000z Notebook
Distorted Colours
your graphic card is going out
Jul 11, 2009 | Microsoft Xbox 360 Console
Colour distorted after laptop fell
its better you should take it to the technician, i think the cable that gives signal to the panel has become faulty
Nov 24, 2008 | Acer Aspire 5610 Notebook
Panasonic rear projection tv colour distortion
Does the picture appear 3D? Can you post a pic or describe the distortion more i should be able to help you out with theproblem
Jun 05, 2008 | Televison & Video
COLLOUR DISTORTED
actually your tv set was placed near object produced magnet especially speakers, used magnet, small one to de-gauss or just like cleaning the the tv screen untill impurity colors gone. need my help....dnlsabangan@yahoo.com
Feb 14, 2008 | Televison & Video
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
