Question about Creative Technology Inspire T10 2 Speakers
Right speaker much softer then left speaker
I just got these speakers yesterday along with my computer (which uses windows 8) I plugged them in and at first it seemed like my right speaker (the one with the volume control) wasn't working at all, however, I unplugged the left speaker entirely and the right speaker does work, it's just much, much softer. I had to turn the volume right up to get any sound out of it. Is there any way to fix this? I know it's not the computer because when I plug my headphones into the computer port both sides work just fine.
  • CHAD LAHTI
    CHAD LAHTI Dec 26, 2013
    Hi Elizabeth , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Make and model of system and also have u tried other speakers to see if its a computer hardware issue or back line out on your speakers
    Thanks
    Chadman
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I just bought the Creative T40 II series speakers.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Posted on Feb 21, 2011
Mr BrokRench
  • 1623 Answers
SOURCE: just built new pc and
I would get a repair estimate on the speakers, could be just a bad solder on the inside of the case. If repairs are going to cost over 100 dollars, then i would replace them. At least you know it's the speakers and not your audio card or integrated audio on your motherboard. I hope this helps.
Posted on Aug 28, 2011
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
ONly my Left Speaker works not my right all i did was unpluged it and it stoped working
Can you check it on another computer and see whether it is a problem with the speaker or the plug, or the computer port or the software settings. Make sure it is turned on and the volume settings on the speaker and the operating system are right. Mute buttons are off. The cable connection is right. Power source is supplied to the speakers if any. If it is the speaker problem, you may seek warranty fix or do some circuit fix googling. If it is the computer, then you can perform a system restore to the date it worked or use the following link to check audio settings if you are using Windows.
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
http://windows.microsoft.com/en-us/windows/help/no-sound-in-windows
http://support.microsoft.com/mats/no_sound
Apr 16, 2011 | Logitech X-240 Computer Speakers
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
I've tried three different sets of speakers and each time the left speaker will not work. I've also tried plugging in my headphones and my left headphone wont work. I've checked all the volume controls and...
Well the jack you plug in has three surfaces. So when you pulled it part way out then the left speaker part of the plug came in contact with the right speaker contact inside the jack and it worked. Speakers are good so if you have checked your volume control in Windows and checked that the balance control is centered it could be that your sound card is defective. You didn't tell me what kind of computer you have and if the sound card is built into the motherboard or if it is an add on card. I don't know if you only have the Window's sound control in Control Panel or if your card has a seperate software for configuring your card but I think the only thing that might disable the left speaker has to be the balance control in Window's sound control or the seperate software.
Nov 15, 2009 | JBL CREATURE II Computer Speakers
Del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Sep 14, 2009 | Dell HK395 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Creative Technology Inspire T10 2 Speakers Logo
Top Creative Technology Audio Players & Recorders Experts
Jim Y
Jim Y
aliasger yq
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
