Question about Vertex Radio Communications
Digital tone not bringing up repeater - Vertex Radio Communications
  • 3 Answers
Without knowing the model of radio or the specific repeater you are trying to access, the only things I can suggest are 1) check to make sure your radio is setup for duplex operation, 2) check to make sure the offset is correct for the repeater, 3) make sure you are in tone mode (not tone squelch mode) and that the tone is correct for the repeater, 4) if the repeater is still not coming up, listen for a while to see if others can access it. If you don't hear other traffic on the repeater there is a possibility that it is down.
Other information that would help get you an answer would be the make / model of the radio (you said Vertex but that could also mean Yaesu), and information on the repeater you are accessing (frequency, location, repeater callsign).
Posted on Dec 30, 2013
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Lands Phones
FT-90R Pl 136.5 does not open repeaters. Other radio detects the tone. Other PLs work.
check to see that your radio is set to encode or send the 136.5 tone and that it is not set to decode. Most ham repeaters do not transmit the tone so if your radio is set to decode 136.5 and the repeater is not transmitting the tone it will mute and you wont hear anything.
Jun 13, 2014 | Yaesu Radio Communications
What does reorder tone mean?
A busy tone (Busy Signal) and a reorder tone are two similar on-off repeating tones that differ in the spped that they beep on and off. Some lay terms for a reorder tone is a Fast Busy tone. Both types of tones use two different frequency tones simultaneously, 480 and 620 Hz, for the beep sound. Busy tones are a half second of tone and a half second of silence, repeated. Today's reorder tone is a quarter second of tone and a quarter second of silence repeated, twice as fast as a busy; a long time ago the cadence was a little different.
May 05, 2014 | Panasonic KXDT343 Phone
How do I program a yaesu ft-270?
I will be working from the online version of the manual located here. It may or may not be the same as your printed manual included with the radio - so you might want to download this copy.
First, let's set the radio to automatically set up repeater input shift based on the published receive frequency. By default, the 270R will transmit 600Hz up or down as determined by the band plan. This feature is called ARS and can be disabled if desired. If it does not display a frequency 600Hz up or down from the receive frequency while transmitting, is has been disabled. Let's re-enable it by performing steps #1 thru #5 on page 19 of the manual. Once completed, the 270R will automatically shift the transmit frequency (to match the repeater input frequency) as shown in the top half of the "ARS-Repeater Subbands" graphic at the bottom of page 19. The bottom half shows the export version of the shifts and does not apply to USA versions. If you have "odd splits" (repeaters that have input frequencies that are non-standard ie: other than 600Hz; or shift up instead of down and vise-versa) you'll need to manually change these later as described in VHO Split Mode on page 21. Any repeater operating on 147.000Mhz may have a shift either UP or DOWN. As you can see in the graphic, 147.000 is between the (-) and (+) shift so it could be either direction. Double check to make sure the radio matches the shift that the particular 147.000Mhz repeater you wish to access requires.
Next, create a list of repeaters that you wish to save in memory (you can check online databases to obtain the most recent information). This list should include Name, Receive Frequency, any non-standard direction or value Shift (called "odd splits), Tone Type and Tone. The name should be 6 or less alpha-numerics in length and be something that helps you identify it . This could be the name of the repeater owner: "TIM, PETE, etc. ", the name of the club that runs it: "BARC, CMARA, etc.", the city or town it is in: "BOSTON, OAKLND, etc,". You might run into names that would create duplicates when there are more than 1 repeaters there in the same location. Boston has several 2M repeaters - naming them BOSTN1, BOSTN2, etc. may help you remember them, but it will be easier still to append the decimal portion of the frequency to remember - such as in the case of a Boston repeater on say, 146.030Mhz and one on 145.150. BOS030 and BOS150 would probably be easier than trying to remember which is BOSTN1 and which is BOSTN2. Placing the names in the 270R memory is the last thing done, so don't worry too much about a name for the 270R's display just yet.
Most repeaters use CTCSS for access. Some newer repeaters use DCS. Some require or even prefer that no tone be sent at all. CTCSS is an analog frequency and a DCS code is digital data. The repeater may require one or the other to be present to "wake up" and begin retransmitting your message. All you really need to know about these two systems is the you need to match both the tone type and the tone value to successfully activate the repeater. Set the radio to your desired default power output level. Tap the VFO button once to enter VFO mode (if not already in VFO mode).
Enter the repeater's receive frequency by twisting of the tuning dial (page 13) or by direct entry (page 14) via the keypad. When using the keypad, do not enter the leading "1" of the frequency - as all the frequencies that this radio can tune begin with "1" and can not be changed. With the repeater frequency displayed, next enter the CTCSS tone for the repeater as described on page 23. If the repeater uses DCS, follow the directions that begin 1/3 of the way down on page 24 instead. As far as "TONE" and "TONE SQ" are concerned, the difference can best be described in that a radio working on a repeater system benefits from use of TONE, and a radio working on in simplex operation (no repeaters) benefits from the use of TONE SQ. Since we're programming repeater frequencies, there's no need to select TONE SQ. If the repeater strips the tone from its output, your radio will remain silent if set for TONE SQ. TONE is a much better match for our needs. Remember, you must use the DIAL to select the CTCSS tone frequency or DCS Code. Unlike the repeater receive frequency, it is not possible to directly enter the tone frequency or code via the keypad.
At this point, the radio should be displaying the recieve repeater frequency. Since automatic repeater offset is enabled - the 600Hz offset frequency and direction are set. The tone type and value for this repeater frequency have just been set in the previous paragraphs as well. Now it is time to write all this information to the radio's memory. This is detailed 1/3 of the way down on page 29 under "Memory Storage". Once you have performed step 5 in Memory Storage for this first repeater, it says to repeat this same process. This means setting the next repeater's recieve frequency, tone type and tone value - just as you have done with the first.
Once you have made sure that you have unique names assigned and the other information above, you are ready to begin adding them into the 270R's memory. You can go back add names to be displayed instead of the frequency of the repeaters if desired. Page 31 details the procedure to assign an alpha numeric name to each memory location. Make sure that you are assigning the correct alpha-numeric to the repeater by checking the frequency from time to time - don't blindly add alpha-numerics to memory channels.
This is a very tedious process. Ham Radio Outlet offers Windows programming software and transfer cable by Yaesu called "ADMS-270" for $38.95. This package allows you to easily create many lists of memories on your Windows PC & keyboard that can be uploaded and downloaded "on the fly" I highly recommend this software - or any software that allows you to program the radio from a computer rather than the radio itself.
I hope this was helpful.
Nov 29, 2012 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Yaesu ftm-10e squelch problem
The FTM-10E is the european version of the dual band amateur radio capable of transmitting in the amateur VHF & UHF (144Mhz & 440Mhz ) bands, that is equal to the FTM-10R sold in the US.
Many repeaters require a predetermined sub-audible tone or signal to be sent when transmitting. If several repeaters in the area operate on the same frequency, they would all transmit at the same time unless they all have different sub-audible tones. These tones allow the user to select which repeater on the same frequency will be used. The tones are either CTCSS or DCS type. CTCSS is "continuous tone coded squelch system" and DCS is "digital coded squelch". CTCSS is expressed as a frequency in Hertz and DCS is a code expressed as a number. CTCSS is more popular, since it has been around longer. When programming or tuning the radio, you will need to provide the repeater's output frequency (and the input frequency if the shift direction and amount isn't programmed - often a 600 hertz shift either up or down depending on isn't already programmed is a default value depending on the repeater output frequency) and whether or not the repeater requires a tone. If it does require a tone (most do), you will need to know the type (CTCSS or DCS) and the value (frequency for CTCSS or code number for DCS) in order for your transmitter to open the repeater and cause it to repeat your transmission AND open the squelch on the radio's receiver so that you can hear replies to your call and other conversations. Repeater directories (both printed and online) will provide all the information needed to access a public repeater, including geographical location, input & output frequencies, squelch type and values to name a few.
If you do not have the correct CTCSS or DCS set, you will see the signal meter on the radio indicate traffic - but you will not hear anything because the radio is squelched. Check the manual page 40 for information on how to program the squelch, and page 42 describes the "shift" I mentioned above. Page 64 & 65 details the theory of squelch via CTCSS and DCS and will help you understand it better.
Basically, you have a "standard" squelch - the knob on the radio and a second squelch that is either CTCSS or DCS. Both types must be set to hear anything. Not having the CTCSS or DCS set will prevent your signal from being repeated by the repeater.
If you have more question, please add them in a comment. I hope this helps & good luck!
Jun 17, 2012 | Yaesu FTM-10R VHF/UHF Mobile Dual-Band...
On my Nikon D70s, when I take a picture and see the image previewed briefly on the back LCD, the highlights flash negative image tones(black) in about 1/2 second intervals. This same effect is also present...
There is nothing wrong with your camera. What you are seeing are the blown-out highlights. Those are the portions of your image that have been overexposed so completely that they have lost all detail and will show up as pure white. In most cases the proper fix is to reduce exposure to bring back the detail.
If you simply don't want to see the "blinkies", press up/down on the multiselector repeatedly to cycle through the different views of your images.
May 16, 2010 | Nikon D70s Digital Camera
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Radio Communications Logo
48 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
