NEED TO REPLACE THE POWER JACK ON MY DELL XPS L501X
THE POWER JACK IS BROKEN AND WONT CHARGE THE BATTERY AND I DON'T KNOW HOW TO REPLACE IT ALTHOUGH I DO HAVE THE NEW JACK
harvester3
  • 181 Answers
SOURCE: dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Posted on Nov 27, 2008
  • 54 Answers
SOURCE: DC Power Jack broken need part number to replace it
Contact the manufacturer, they should be able to reference the part number from the model number of the laptop.
Posted on Jan 20, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Posted on Apr 26, 2009
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
SOURCE: Need to replace Power Jack on motherboard for Dell 5150
its not too difficult, you just need the proper soldering stuff and the confidence to do it. On the 5150 you do have to remove the screen, keyboard, drives and worst of all, the processor in order to get to the power jack. the motherboard needs to be removed from the case so that you can get adequate access to do the job. it reminds me of changing a water pump on a car- you have to dismantle half the engine just to get to it but once your there its only 2 bolts. the hardest part is remembering where everything goes back and in what order and making sure that all the right screws go back in the right places when reassembling. it can be done in about 1-2 hours for a beginner. most computer repair places charge about $100. and if you have not already aquired the replacement jack you can find them on eBay for $6-15
Posted on Aug 17, 2009
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
Dell xps l501x wont read disc
if any disc then change dvd writter
Oct 24, 2012 | Dell Dimension E521 PC Desktop
My Dell insperion won't power up at all. I bought a new battery and tested the charger and am getting the 19.5V that I am supposed to get. I don't know how to test the battery to see if it is...
If working should turn on with adapter plugged in, maybe the internal jack is broken, move adapter plug around slightly and see if it moves at all, should not. Does any lights com on or do you hear the fan ?
Nov 01, 2017 | Dell Inspiron 1150 Notebook
Dell xps-m1330 no power .no light
Power plug or power jack...
pull the battery out and retry with battery out,, pluged in,
If its not the power plug, power jack or bat., then the motherboard may be bad.
May 16, 2010 | Dell XPS M1330 Notebook
XPS M1330 issue -- laptop won't charge battery using power adapter which has been replaced. The unit will only work with the power adapter plugged into electrical outlet. How can I tell if it is truly the...
Try another known working battery in the laptop and see if it charges, if it doesn't then its going to be a problem with hairline cracks in the dc jack on the laptop. The solder points underneath the dc jack if they have hairline cracks in them won't allow the battery to charge. Basically the laptop would need to be taken apart and the motherboard taken out.
If you have soldering skills, all that needs to be done is to put new solder on the solder points that hold the dc jack in place.
If after you do this the battery still wont charge then you know for sure the connector is bad and then the connector would need to be replaced.
Aug 20, 2009 | Dell XPS M1330 Notebook
Dell Studio XPS Laptop Won't Boot
if the charging light doesn't come on i think it would be your power jack in your computer loose. this is not a home fix if so it would need to be sent off to get done. i would definitely suggest doing this especially if it is the problem and because if its under warrenty still they will fix it.
May 07, 2009 | Dell Studio XPS 16 Notebook
Need replacement headphone jack.
Hi there.
You can get a replacement jack from any electrical store or radio shack store.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Inspiron XPS M140 Notebook
Wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
May 05, 2009 | Dell Latitude D510 Notebook
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Wet Dell XPS M1210
I would try cleaning the terminals on the battery and the computer with an old toothbrush and simple green or other multi-purpose cleaner, that doesn't leave residue.
Jul 13, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
