Question about Dell Inspiron 1521 Notebook
Windows Failed to load because Kernel file is missing
Recently, my hard drive wouldn't load because a system32 file was missing so I tried reinstalling my windows vista OS onto the hard drive. When the installation process gets to the part where the computer restarts and windows has to load for the first time it says that "Windows Failed to load because Kernel file is missing, or corrupt" any ideas on what I should do?
Also, another problem is I just bought a new Seagate 320GB hard drive and it was working great for a week then I turned on my computer with that hard drive in and it says that no internal HDD can be found. I reseated it and everything. Even tried putting it in a freezer for a while to get the disk running and everything. Please help!
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    how did you reinstall your windows? have you tried pc restore instead?
    Problem Solver:
  • 16 Answers
Try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
Posted on Jun 01, 2009
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Are you talking about two problems on one computer? If so, the first problem doesn't matter until the second one is fixed. If you are talking about two different computers, then the problems can be each addressed.
For the hard drive that is not recognized, where did it come from? If you purchased it used, you may be out of luck. It sounds like you have a pretty good idea how computers work, and it also sounds like this hard drive does not work at all.
If these are both the same computer, then replacing the hard drive with a known working hard drive will most likely provide you with a solution.
I wish I had better news for you.
May 17, 2009 | Dell Inspiron 1521 Notebook
\window\system32\ntknlpa.exe
Hope its under warranty probably a failing hard drive.
Mar 12, 2009 | Acer Aspire 5610-4648 Notebook
0XC00000E9
try cleaning your Cd.
Failing that you could borrow an operating system disk to get windows up and running and then get all the drivers etc from your restore disks
Mar 09, 2009 | Acer Aspire 5610-4648 Notebook
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
sys file from the cd is corrupted...try wd any other disc
Aug 02, 2008 | Compaq Presario Notebook
Dell Inspiron 1521 Notebook Logo
618 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
