Question about Whirlpool Dryers
Gas dryer burner cuts off after a few minutes of use
I have a Whirlpool Elite 2 gas dryer. The burner will light and run for a couple of minutes then cut off. The igniter glows and tries to light but no flame. After a while of tumbling with just air or if you turn it off for a few minutes it will relight. I checked for obstructions in the exhaust vent and cleaned out lint. Still no luck. It will run and heat for a couple of minutes and then the flame will go out. I am running the dryer in the timed cycle with the heat set to high heavy. I am thinking I have a bad solenoid. Any ideas where to go next? Is there an internal flap/damper in the exhaust vent that could be staying closed and causing it to run hot and the burner to shut off? Thanks
  • angellesappl May 19, 2009
    I replaced the gas solenoid coils and dryer is working fine again.  Thanks for your feedback.
    Scholar:
  • 85 Answers
Your gas solenoid coils are bad. Replacing them will solve your problem.
Posted on May 18, 2009
Right front burner ignites normally then suddenly goes to very low flame. i remove the disk on it and run a fine wire through the hole where gas comes out. the flame is normal fora few minutes then shrinks...
The jet you were cleaning with the wire is not the problem here - if it would have been clogged by dirt the flame would have been low always.
This gas range has a flameout protection - a bimetal sensor that should cut off the gas when the flame extinguishes. In your case the sensor on that burner is malfunctioning - when it heats up it cuts off the gas instead of opening the control valve. You will have to replace it . For that i strongly advice you to call a certified repairman - it's a complex job on which you cannot allow leaks.
Nov 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Have Whirlpool Model # LGB6200PQO dryer runs but does nut dry. Burner kicks on with fire on gas dryer but after about 5 min kicks off after a few minutes the igniter glows on but no fire then kicks off...
The moister sensor can be bad or good. If the exhaust tubes are clogged with any lint build upo the sensor is working putting the burner into check
Jul 28, 2010 | Whirlpool Dryers
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
HEAT ONLY STAYS ON FOR A FEW MINUTES. WE HAVE ALREADY CLEANED OUT ALL THE LINT FROM EVERYWHERE.
replace the 2 coils on the burner . After they warm up , one will "short" , therefore the gas will not come on unless cooled down for a bit .
Aug 14, 2009 | Whirlpool LGB6300 Gas Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Whirlpool gas dryer rotates, gas ignites but goes out, won't reig
coils on the gas valve, especially the single coils that whirlpool uses, break down after use. They may ohm out good when cold and the burner may light 1, 2, or 3 times, then you get ignition failure. Coils are bad. Hint when replacing coils. the front coil which has 3 terminals has a metal sleeve inside the coil. Make sure that sleeve stays with the valve. It can get stuck in the old coil and thrown away. Good luck
The Squirrel
Mar 26, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
245 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
