Question about Alpine MRX-M50 - Monoblock 500 Watt RMS Subwoofer Amplifier
Subs cut out when bass hits - Alpine MRX-M50 - Monoblock 500 Watt RMS Subwoofer Amplifier
    Novelist:
  • 111 Answers
Assuming that both subwoofers are working fine: check what voltage output your headunit has (RCA output voltage) and match it to your amplifiers input sensitivity (GAIN) eg: if your headunit has 4 volt outputs then on this particular amplifier your gain knob would be completely to the left as if in the off or 0 posirion.
if u are not sure of your headunits output voltage you could check the manuals specification page or send me the barand and model number of your headunit and I will check it for u.
hope this helps. let me know if I can assist you any further.
.......andy.......
Posted on Jan 05, 2014
2 Suggested Answers
  • 631 Answers
SOURCE: amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Posted on Sep 19, 2007
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
Hi i just got 2 new infinity 860w reference 8'' subs 250 rms each and pushing it with sony 600watt amp pushing it but very low sound and no bass why the othier speakers i have in 10'' hit the bass fine but...
The amp may no thav eenough to push these subs, these are top of the line subs, they probably require a bigger amp, if you are running other speakers through this also, you certainly need another amp, or a bigger one with more channels. also double check all your wiring.
Mar 29, 2011 | Jl Audio 12W7 Car Subwoofer
What would cause my fossgate t1500 to shut off everytime the bass hits hard I have two t12s that it pushes
Sounds like your amp isnt powerful enough to power your subs, whats the wattage of your amp and both subs? Its shutting off when hard bass hits to protect itself from blowing, a good feature as a blown amp means a new one. an amp should always be more powerful than the speakers / subs you are connecting to it. for 2 500w subs your looking at a 1200w amp minimum.
Feb 22, 2011 | Car Audio & Video
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp cuts off
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
Alpine MRX-M50 - Monoblock 500 Watt RMS Subwoofer Amplifier Logo
74 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
