Question about Pioneer VSX-406 Receiver
Sub won't work
I cannot get the sub-woofer to work even when its hooked up to my vsx-406, all the other speakers work just fine.
  • David Dunn
    David Dunn May 11, 2010
    What is the sub and how are you trying to hook it up? I haven't found a manual for this thing but my gut says it doesn't have a subwoofer amplifier. is your subwoofer self-powered? What happens if you connect the sub to a working amplifier channel? We need to be certain the sub works before we go into the receiver for a fix.
  • 92 Answers
If using a sub out cable to a powered sub,you have to go into the reciever menu and turn the sub out on
Posted on May 20, 2009
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Brand newpioneer vsx 822k sub-woofer won't work
Make sure front speakers are set to small. If you set them to large, the subwoofer output in turned off.
Mar 18, 2013 | Pioneer Audio Players & Recorders
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I get no sound out of my sub woofer. I've triple checked the setup for speakers. I've had this unit for years so I'm familiar with the setup. I've taken the speaker to another stereo and it works fine....
check the cable for you sub woofer. If problem exists. Try another cable to verify. What kind of subwoofers are you using? Are you going through the LFE port or are you running speaker wires through the speaker inputs on the sub?
Dec 08, 2010 | Pioneer VSX-D908S Receiver
How do I connect using black and red cables a pioneer VSX-406 sub
Black would be minus - and red would be plus + but this will only work if your receiver actullay has a + and - binding post specifically for the sub woofer. Sometimes you will have wiring binding posts and other times you will have a rca phon plug and maybe your sub has that as well
Dec 04, 2010 | Pioneer VSX-406 Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
320 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
