Question about Graphtec America, Inc Silhouette Studio Designer Edition
Silhouette crashes After starting pgm stops suddenly
I have a 1996 Acura 3.5 R.L. just put a new fuel pump in and it won't start. It turns over, but will not stay started.
Check your main fuel relay.
Fuel Supply System
PGM-FI Main Relay
Description
This PGM-FI main relay is located behind the dashboard
lower cover. The PGM-FI main relay actually contains
two individual relays. One relay is energized whenever
the ignition is on. It supplies battery voltage to the PCM,
power to the fuel injectors, and power for the second
relay. The second relay is energized for 2 seconds when
the ignition is switched on, and when the engine is running.
It supplies power to the fuel pump.
PGM-FI
MAIN RELAY
FUEL
PUMP
RELAY
Relay Testing
NOTE: If the engine starts and continues to run, the PGMFI
main relay is OK.
1. Remove the PGM-FI main relay.
2. Attach the battery positive terminal to the No. 3*
terminal and the battery negative terminal to the
No. 2* terminal of the PGM-FI main relay. Then
check for continuity between the No. 5* terminal and
No. 2 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 3.
• If there is no continuity, replace the relay and
retest.
*: 8P CONNECTOR
To FUEL PUMP
3. Attach the battery positive terminal to the No. 4 terminal
and the battery negative terminal to the No.
7* terminal of the PGM-FI main relay. Then check
that there is continuity between the No. 3 terminal
and No. 1 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 4.
retest.
4. Attach the battery positive terminal to the No. 1 terminal
and battery negative terminal to the No. 2*
terminal of the PGM-FI main relay. Then check that
there is continuity between the No. 5* terminal and
• If there is continuity, the relay is OK;
If the fuel pump still does not work, go to Harness
Testing on the next page.
retest.
To PCM CONNECTOR
TERMINAL A4
To ST. SWITCH
To GROUND
To IGN. 1 To BAT
To PCM
CONNECTOR TERMINALS
A13 and B1
FUEL PUMP
RESISTOR
FUEL PUMP
Sep 18, 2013 | 1996 Acura TL Series
Games suddenly stop working
Well it might be that the GameCube is over heating then by the fan not working properly to help cool down the console so it will have to be fixed then
Jul 25, 2012 | Nintendo GameCube Console
Car cranks but dose not start, there is no power to distributator or fuel pump
I suspect the at this point, the main relay is defective. This relay controls power to fuel and spark circuits.
The PGM-FI Main Relay is actually comprised of two individual internal relays. When the ignition switch is initially turned ON , the Powertrain Control Module (PCM) supplies ground to the PGM-FI Main Relay. This ground triggers one of the PGM-FI internal relays that sends battery voltage to the fuel pump for two seconds to pressurize the fuel system.
When the engine is running the PCM supplies a continuous ground to the PGM-FI Main Relay. The supplied ground keeps the relay in the "closed" position providing electrical current to the fuel pump, keeping the fuel loop pressurized while the engine runs.
If the engine is not running with the ignition on, the PCM cuts the ground to the PGM-FI Main Relay, causing the relay to "open" and stop the electric current flow to the fuel pump. As mentioned previously, if the engine is not running, the PCM will only supply ground to the PGM-FI Main Relay for two seconds when the ignition switch is initially switched to the ON position.
The PGM-FI Main Relay also supplies electrical power to the Idle Air Control (IAC) Valve and to the fuel injectors.
TESTING
If the engine starts and continues to run, the PGM-FI Main Relay is working and does not need to be replaced.
  1. Locate and remove the relay.
On some models of the Civic and Civic del Sol it is located to the left of the steering column under the dash. Many later models position it either near the passenger right side kick panel under the dash or by the driver left side kick panel up under the dash.
  1. Attach the battery positive terminal to the No. 2 terminal.
  2. And the battery negative terminal to the No. 1 terminal.
  3. Check for continuity between terminal No. 5 and 4.
  4. If there is no continuity, replace the relay and retest
Aug 05, 2010 | Honda Civic Cars & Trucks
My computer had some problems so i rebooted it but when the windows xp logo came in it suddenly stops and starts making weird noises. It also happened before i rebooted when i watch some videos online.
Sounds like your hard drive is crashing or has crashed. You will most likely need to get a new hard drive and reinstall Windows on it. I hope you have your important files backed-up.
Mar 13, 2010 | Acer Aspire One PC Notebook
Turn signals get no power
Sounds like the switch could be bad.
Jun 19, 2009 | 1992 Oldsmobile Silhouette
Message in display "Sys-Pgm No?"
there is a slide switch where you the connect the telephone cord to the phone. Switch it it normal mode.
May 01, 2009 | Lands Phones
Graphtec America, Inc Silhouette Studio Designer Edition Logo
562 people viewed this question
Top Graphtec America, Inc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Graphtec America, Inc Office Equipment and Supply Expert? Answer questions, earn points and help others
