Question about Quinny Baby Gear
Dying a quinny seat - Quinny Baby Gear
Does the new quinny zapp extra hood fit onto the old style zapp? Or any other quinny hood? I don't mind removing it before folding.
Hi
No the new Quinny Zapp Xtra sun canopy is part of the seat fabric.
If you wish to turn your standard Quinny Zapp into a Quinny Zapp Xtra you need to purchase the Quinny Zapp Xtra seat unit as an accessory from your local retailer as it will have the seat frame and the adaptors required to fit it into the chassis you have.
Visit www.quinny.com to find your nearest retailer.
May 14, 2012 | Quinny Baby Gear
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Jan 11, 2011 | Quinny BUZZ 3 Capri Stroller
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
Are Quinny Freestyle 4 XL car seats universal??
WE ARE SHOPPING AND ARE LEANING TOWARD THE QUINNY 4XL. THE SEAT DOES FIT THE MAXI COSI STROLLERS AND SAFETY FIRST STROLLERS. I CHECKRD YESTERDAY AT SEARS.
Feb 01, 2010 | Quinny Freestyle 4 Marina Stroller
New car seat, quinny freestyle
what you need is a maxi cosy infant seat. these are the ones designed to fit quinny freestyle frames. you will also need attachment bars that you can easily buy on ebay for a coulpe of pound.
hope this helps
Mar 10, 2009 | Quinny Freestyle 4 Marina Stroller
Quinny Buzz Seat Unit 2008
i contacted quinny because the straps on my quinny had become too tight for my 1year old. Quinny responded informing me that it has come to their attention that the 07/08 quinny buzz was made with smaller straps and that the seat padding was much thicker, causing them to quickly become too small. Second stage seats are now sold as standard to give extra room, but if you purchased your pushchair before this, to contact the retailer to recieve your free second stage seat cover. The result being that my 1yr old now fits in quinny.
Feb 15, 2009 | Quinny Buzz 3 Sulphur Jogger
I purchased a quinny zapp and am wanting to take of the pushchair material in order to fix the maxi cosi cabrio fix car seat to the frame can u please tell me how.
Removing Seat
It is necessary to remove
the seat from the frame
when preparing to use
the car seat adapters.
Unzip seat zipper at the
back of the seat.
To unclip the seat from
the frame,
fold stroller enough to
relieve the tension on the clips.
To view instruction manual with pictures for further assistance. Go to the Quinny page below and download the manual.
http://www.quinny.com/quinny/productdetail.aspx?id=29
Good Luck! from Moms Just Know
Oct 23, 2008 | Quinny ZAPP Stroller
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Baby Gear Logo
26 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
