Question about Epson PLQ-20 Matrix Printer
Fix paper jam
When print bankers cheque - it stuck.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check paper feed gear
Posted on Dec 28, 2013
3 Suggested Answers
gwbm
  • 353 Answers
SOURCE: paper jam epson c84
If you are sure that no scraps of paper (or other object) is jamming the paper feed path, you will need to dismantle the printer to investigate further. This is really a job for a technician; however, if you want to have a try yourself, you can download the service manual from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Also, post a new comment to this effect since I can provide useful extra info on getting these difficult machines apart.
Posted on May 11, 2009
  • 10 Answers
SOURCE: Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
Posted on May 31, 2010
Why my canon printer is saying paper jam?
here is nothing wrong in saying, "paper jam issue in canon printer " one of the most irritating issue.
especially when you are going to print any import document and it got stuck in the middle of printing.
when we face paper jam issue with our printer. we always try to contact to a technical expert for fixing such kind issue. while most of us don't know, you can fix paper jam issue in canon printer by yourself without inviting any technical person at your home.
For More details check this
how to fix paper jam issue in canon printer by myself Fixotip
Jan 02, 2018 | Canon Office Equipment & Supplies
How to Fix Paper Jamming Issue in HP Printers?
not sure if this helps...
Skip to the two-sided printing accessory section if you have a two-sided printing accessory instead of a rear access door.
  1. Turn the knob on the rear access door counter-clockwise.
  2. Remove the door. ...
  3. Pull the jammed paper out of the printer. ...
  4. Check to make sure no scraps of paper are stuck in the printer.
More items...
HP Deskjet 900 Printer Series - Clearing a Paper Jam ' HP® Customer ...
https://support.hp.com/us-en/document/bud09128..
or go to this link...
How to Fix Paper Jamming Issue in HP Printers Google Search
Oct 27, 2017 | HP Office Equipment & Supplies
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
My printer HP Deskjet 1051 says there is a paper jam but no paper jam present
Use a flashlight to examine as much of the paper path as you can see. There may be a shred of paper left over from an earlier jam. There might be some foreign object such as a paper clip stuck inside.
Sep 14, 2012 | HP Deskjet 1051 All-in-One Printer
AFTER PAPER JAM WILL NOT PRINT
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 20, 2010 | Lexmark E232 Laser Printer
I did a front feed on my Brother HL-1230 printer and now the cheque is jammed in the printer. How do I get to the drum to remove the cheque?
Open the front of the printer via the 2 tabs on the sides of the front door. Lift the toner/drum assembly out of the printer. You should be able to see the paper in the unit. Carefully pull the paper out of the unit. You may want to run a few pages through the printer to pick up any residual toner before printing another document.
Jul 16, 2009 | Brother HL 1230 Laser Printer
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Nov 30, 2008 | Canon CLC 1140 Copier
Print cartridge stuck
Hi please click on the link below to know exactly what you need to do to fix paper jam problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09128&lc=en&cc=us&lang=en&rule=1823&product=77146&dlc=en
Please let me know if it fixed the problem or not.
Cheers
Jun 10, 2008 | HP PhotoSmart 7960 InkJet Printer
Epson PLQ-20 Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
