Question about Santai SD-563A LCD Cycling Bicycle Bike Computer Odometer Speedometer Waterproof
How do you reset computer after each ride? - Santai SD-563A LCD Cycling Bicycle Bike Computer Odometer Speedometer Waterproof
Air suspension system Check ride control warning
Is your mechanic in a factory shop > many automobiles error messages are generated by the main computer which needs to be reset by the dealership computer, Others can be reset with an OBD reader or a combination of inputs like locking and unlocking the drivers door a number of times rapidly.
Oct 14, 2015 | 1997 Lincoln Continental
The distance, current speed, maximum speed, average speed and odometer are not correct on my rides. The wheel calibration is set correctly, as is the installation with the distance between the sensor
It sounds like your computer reset itself. This may be due to a sticky button, as most computers are installed at the same place where folks have their aero bottles. Some of the nice sticky glucose liquid runs onto the computer face when you drink, gumming up the buttons. Try wiping your computer face with a hot damp (not dripping wet) rag. If this is the problem, the hot water should remove the sticky stuff on your buttons and allow your computer to work properly.
Oct 10, 2014 | Topeak Panoram V12 Mini 12 Function Cycle...
I recently did a complete brake job on my 2005 GMC Yukon XL, 4 wheel drive. The air suspension was working fine before I did the brakes....the vehicle was suspended on jacks for over a day due to some...
Have you tried removing the Ride Control fuse (RTD - real time damping) so the system has to go through factory initialization again on power-up?
If this doesn't reset the system - it detects a condition on its sensors which causes it to trip and display "Service Ride control"
Jun 30, 2011 | GMC Yukon XL Cars & Trucks
I have bought a second hand bike which has a bikehut 14 computer attached but i do not have the manual to show me how to reset the configurations. Could you please advise?
If you want to reset the previous stored configurations you have to hold down the mode button,until the screen is blank, the values of AV (average speed), MX (maximum speed) and TM (time riding), will be then zero. To reset the ODO (odometer) instead, you can press a little hole on the back of the bikehut.
Have a nice ride!
May 31, 2011 | Cycling
I can not remember my power on password. What can I do to over ride or reset it?
> problem with barcode scanners
Press the RESET button on the scanner.
Or, if you have a DESKTOP computer, you can do a "BIOS RESET" to delete the password.
If you have a LAPTOP computer, find the original sales-receipt, to prove that you, rather than a thief, is in possession of your computer, and telephone the manufacturer.
If you have some other electronic device, please tell us what it is.
Jan 15, 2011 | Computers & Internet
Garmin 305 would not turn on after a ride. would
Reset your unit by pressing the "Mode"(reset/lap) and "Power" buttons at the same time. afte it turns on run system updater on computer
Jan 10, 2010 | Garmin Forerunner 305 GPS Receiver
I have a 95 Lincoln Continental, the back end was way too high so I released the air in the bags. Now the only problem is that the pump can't lift up the car. Is there any ways to get air into the system...
located on the air suspension pump, there is a air fitting on top which you can inflate with an air hose, start the car and when the pump comes on, add air......it should stop pumping when the ride height sensor gets to the adjusted height....hope this helps....GL
Jul 08, 2009 | 1986 Lincoln Continental
Just got a dash warning "SERVICE RIDE CONTROL."
On second thought I understand you meant the indicator said actually "service ride". This can apply to shocks, the air pump that levels the car, possible low tire and such. Again, a mechanic can read the exact problem with a diagnostic computer. Just keep on driving until you get tired of seeing the warning. Oh yes, the mechanic can reset the car computer and make the annoying warning go away.
Feb 02, 2009 | 1996 Cadillac DeVille
Santai SD-563A LCD Cycling Bicycle Bike Computer Odometer Speedometer Waterproof Logo
52 people viewed this question
Top Santai Computers & Internet Experts
David Payne
David Payne
Are you a Santai Computer and Internet Expert? Answer questions, earn points and help others
