Question about Garden
272xp husqvarna chainsaw leaking bar oil
I Have had this old husqvarna chainsaw for about 13 yrs.,how do I get this chainsaw to stop leaking bar oil? do it require parts? Mark impala_driver09@hotmail.com
  • 3 Answers
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
I USED GOOGLE SEARCH THEN JUST DOWNLOADED IT. I GOT THE ONE FOR MODEL 50, 50 SPECIAL AND 51. GOOD LUCK!!!
Posted on Jan 25, 2009
  • 5 Answers
SOURCE: Husqvarna chainsaw bar bolt loose and leaking oil
had same! was set to release the max amount of oil to bar, but the thread is only so long and will drop out of seat, send it for service and note the bar feeder srew, its faster and cheaper! good luck p.s great saw!
Posted on May 08, 2009
Free download on:
http://lawnandgarden.owneriq.net/ex/thread/view/idThread/278287
Posted on May 15, 2009
puertobori
  • 7733 Answers
SOURCE: i have a husqvarna model
Try to find the oil lubrication tank and replace it.
Posted on Oct 26, 2010
  • 2239 Answers
SOURCE: Husqvarna model 357XP chainsaw leaks oil all over
You need to find out where its coming from, drain the oil tank and re fill with some fuel, as this is much thinner it will leak out much faster and give you a better idea where its coming from, it may be just the pipe up pipe behind the pump has got hard and started to leak, the other possibility is the crankcase gasket, if this is leaking it is a full strip down to fit a new gasket.
Posted on Oct 23, 2011
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
240e chainsaw leaking bar oil
It's quite common, if it's only leaking a little it's not really worth the trouble chasing the leak down. Your saw will have an online manual which may detail disassembly. Mine leaks a touch but not enough to bother me.
Aug 02, 2014 | Husqvarna Garden
Husqvarna 235 is leaking bar oil really bad
Hi, What Kind of oil do You use? A thiker one could be a solution.
Usualy there a other screw (than those H and L of the carburator) to adjuste the amount of oil spend on your blade.
Feb 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the low and high settings on the carb for a 272xp husqvarna
One turn out from lightly seated on both High and low speed jets. Not supposed to use stock answers on here but I just made a post recently that may be of help....Cheers!
http://www.fixya.com/support/t7263870-350_will_not_stay
Dec 14, 2010 | Husqvarna Chain Saw 20" Bar
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
May 06, 2009 | Garden
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
