Question about Exercise & Fitness
Lcd display treadmill
Hello, I have a Osim Ujog 500 treadmill. The LCD screen is totally dead, When the treadmill is turned on, there is a red light, that's all. Please help
  • Yasirhayat Oct 31, 2017
    U Jog 500 tread mill erer 4 plssss can u help me
    Master:
  • Exercise & F... Master
  • 154 Answers
Please open the cover where the motor is there
Tight the connector from the Controller motor Board to the LCD display, and then in the Upper side near of the Console there are Another Connector coming from the Controller motor board, tight and clean very well with contact cleaner Electronic. and try again.
Other wise the Controller motor board is defective and replace.
Blessing
cuadra2016@yandex.com
whatsApp:+50588611441
Posted on Nov 03, 2017
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
Posted on May 22, 2010
caroldon
  • 17130 Answers
SOURCE: THE LCD SCREEN SEEMS TO WORK FINE BUT THE
The LCD displays what the commands are set for by the user but the controller ( microprocessor) outputs the data to the motor drive to work faster.
So in this case it can be a failure off the motor control which is not reacting to the variable settings of the user.
Open the section, check on the drive board for errors.
Posted on Sep 11, 2010
SOURCE: Fuel FT94 Treadmill troubleshooting
It stops and when I unplug it it starts again this happens 4 or 5 times what is wrong?
sig@siglane.com
Posted on Nov 02, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Treadmill stops working after about
Hi gpearce943,
Just to clarify, may I have the specific brand and model of your treadmill? As well as the error message.
Thank you for using FixYa.
Posted on Aug 06, 2011
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
My acer laptop blacked out yesterday but the programes are still running so i shut it down turn it on again and it worked but this morning i totally got a black screen and everything is dead i need help on...
if you still have lights on the laptop working but no lcd display and it sounds like the hard drive is booting then it could be lcd inverter or lcd display also check your memory that could be bad but if you have no power and no lights then its more than likely power on board
Mar 01, 2013 | Acer Aspire Computers & Internet
Reebok 8700es treadmill w/ Universal iPod dock & Ifit Fitness Journal. Display screen is unreadable. Light is on but unable to read the numbers on the screen Treadmill features: Custom workouts,...
If the display is unreadable, the Display resolution is faulty
Time to replace since thee are LCD, this fail.
Call to the supply treadmill manufacturer. or
Treadmill Treadmills Best Treadmill Treadmill Doctor
Blessing
cell+whatsAPP:+50588611441
Nov 08, 2017 | Reebok 8700 ES Treadmill - Silver Service...
Hello, I've been given a Sony Bravia KDL-26ML130 LCD TV which is not working but I believe it may have a repair solution (hopefully!). The TV powers on fine but the display turns off just a second...
This tv problems are those long board call the LCD inverter boards,it is dead.TV should have 1 or 2 long boards that call the LCD inverter boards it it dead,these 1 or 2 long LCD inverter boards only job are to provide a backlight to the tv LCD screen panel to have screen light produce a picture.Tries websites like Shojimmy.com,Ebay.com to buy those refurbihes 1 or 2 long LCD inverter boards for the replacment.
Jun 18, 2011 | Sony BRAVIA KDL-46SL14098 LCD TV
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Proform treadmill zt 5 runs but display is dead
May 21, 2010 | Proform ZT5 Treadmill
Display isn't working at all
maybe the Lcd connector (flex cable interface) was disconnected if you can open it just press it hard.
Jan 28, 2007 | Audiovox CDM8910WW
Exercise & Fitness Logo
242 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
