Question about Generic Wl toys mini rc beetle v939 quadcopter 4 channel 2.4ghz super mini
Wltoys v252 manual - Generic Wl toys mini rc beetle v939 quadcopter 4 channel 2.4ghz super mini
Im having a problem with my wltoys v922 i plug the battery in and the rotor blade spins right away
If the rotor is spinning at maximum speed and cannot be slowed with controller commands, the motor driver transistor is probably shorted.
Nov 14, 2017 | The Toys
Where is the key hole in a sentry V252
i answer if you cant see one there isnt one on it.
May 25, 2017 | Sentry Home Security
Where do you put the key
Lift the push button panel.
I need the factory unlock code for a Sentry Safe v252
I believe you can only get this from Sentry themselves. If not a lock smith is your best bet.
Jun 05, 2016 | Home Security
My wl v912 transmitter will not switch to mode 2
Mode exchange: hold on the switch button and turn on the power switch "at the same time". Did you try this?
You can change rom modes 1, 2, 3 and 4.
Feb 11, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
My v913 helicopter took a little crash to the front and now my controller wont connect to my helly the red light on the helly used to blink to link up but now it just stays solid red
sorry Kyle but you're going to need a new circuit board for that the 913 it crashed and must have cracked or something so you can have to change hair a circuit board
Jan 03, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
How do i change battery in v252 safe please
The plastic plate at the front of the V252 below the keypad has a small hole. Use a pen or paper clip to press into this hole and at the same time slide the plate to the right. This will reveal the battery container (4 x AA). The code will not be lost if you replace the batteries, and this can be done with the door shut
Jan 09, 2011 | Sentry Fireproof Safe
Generic Wl toys mini rc beetle v939 quadcopter 4 channel 2.4ghz super mini Logo
149 people viewed this question
Top Generic Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Generic Toy Expert? Answer questions, earn points and help others
