Question about Dryers
Bosch dry model wte86300 us/02 ser.no,fd8705200147. runs for 5 to 10 min.and stop.timer must be reset. runs same of time and stop this is a vent less there is novent hose!!! CAN YOU HELP MOE
  • 1 more comment
  • gaspumper1 May 17, 2009
    HOPE YOU ARE RIGHT 3TEC.HAVE LOOK AT THIS DRY AND DID NOT KNOW DO!!! LET YOU IF YOU RIGHT GIVE AFEW DAYS AND I WILL GET BACK TOPYOU LOCAL DONT HAVECUE
  • gaspumper1 May 18, 2009
    WHAT ABOUT CODE F03 WHEN DRY STOP MOE
  • gaspumper1 May 25, 2009
    waiting for tec.get info.from bosch.your s
    Sergeant:
    Champion:
  • 219 Answers
To check the moisture sensors. Make sure the dyer is plugged in and all controls are set to off. Next to get into the diagnostic mode press more time, less time, more time, less time, all within 5 seconds. Now all indecator lights on the console are lit up with 88 in the " time remaining" display, if the test mode has been entered. Now this how to check the moisture sensors. Open the dryer door. You may hear a beep sound and the software revision number will be displayed on the console. If this happens there is a short in the moisture sensor system and the moisture sensors need to be checked and probably replaced. If this doesn`t happen,locate the moisture sensors on the face of the lintscreen housing and lay a wet cloth or towell across them. You should hear a beep and the software number will be diplayed on the console. If this happens then the moisture sensors have past the test and your problem is even deaper into the electronics and may reqiure a technician to trace this problem down.I hope this has helped you.
Thanks!
Sandy
Posted on May 18, 2009
  • Sandeep Gupta May 18, 2009
    This indicates that the wash thermistor is "Open Circuit" and I think
    it is situated on the heater assy at the back of the machine.
    Check the wiring and contacts between the thermistor and the PCB. If
    you still get the fault it could be the Thermistor ( which means
    replacing the heater ) or a faulty board.
  • 6,784 Answers
Hi. this is a Operating module(timer) malfunction. simply replacing this device will fix this issue.
This particular module is the brain of the unit. it times the dryer functions and it also regulates the heat level in conjunction with the temp regulator.
Posted on May 17, 2009
Dryer runs 20 mins, stops, must be restarted over and over. run time becomes less and less after each restart.
check thermal switch on back of dryer,join wires together(tape with electrictape so i tdoes not touch body)then turn on,if runs properly there you go.or change timer
Mar 28, 2014 | Maytag Neptune MDE7500AY Electric Dryer
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Stops running during cycle
Replace the timer and all will work ok. The timer is stuck for some reason, you may be able to clean it out if there is any debris but you are best off just replacing it. 25 dollar or so part
Feb 09, 2009 | Dryers
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
SLOW DRYING WITH MAYTAG DRYER
Have you checked to see if there is an obstruction in the gas valve itself or if the solenoid is worn? If there is, it will not allow as much gas through, therefor making a smaller flame and less heat. If not, check for pinched gas flex lines either before or after the gas valve or leaks in the combustion chamber. Also take out the lint trap, seal it up with cardboard cutout with a hole in it, take an air compressor with a blowout valve on it set at about 200psi, cover your face and blow out the trash out of the internal ventilation system on the dryer. Should work better after all this. Hope this helps.
Jan 28, 2008 | Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
