Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron XBR wont trun on
The TV was working perfectly then just shut off one day and wont turn back on??? What can I do to fix it?
  • 121 Answers
SOURCE: POPPING NOISE FROM SONY TRINITRON KV-30HS420
dont use high volt arcing can do lots of damage. unless you can be sure comtng from speaker.
Posted on Dec 01, 2008
jerryg50
  • 1667 Answers
SOURCE: sony trinitron xbr red diagonal lines appears then screen turns
In cannot remember if this model of set uses on the CRT drive board a drive IC for the CRT colour channels, or if it uses descrete transistors. I have had component failure on this board that causes your description. The failure in your case would be with the red channel drive. Most of the time I had the semiconductors fail, and some of the support components.
Most of the time, a failure on this board is caused by some intermittant internal arching inside of the CRT. If this happens, the CRT is starting go defective.
Another cause of this fault is that the CRT is starting to go internaly shorted between the control grid and screen grid. As it heats up, the shorting becomes lower in resistance, and thus causes the pricture to go brighter until the protection turns it off. This would be with the red electron-gun.
With any failure with the CRT, the set is not worth to fix even if you can find a CRT for it.
Jerry G.
Posted on Jan 09, 2009
  • 1274 Answers
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Posted on Feb 23, 2010
SOURCE: MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Posted on Aug 02, 2010
  • 4 Answers
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Posted on Feb 17, 2011
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Dec 24, 2009 | Sony Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Trinitron XBR Try to turn on but light just
Look for the service manual, it contains the explanation of the flashing light codes, it will tell you what part is faulty.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 20, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
