Panasonic PT-D3500U Multimedia Projector Logo
Posted on Oct 17, 2007
The projectors periodically go to a blue screen in the middle of a presentation.
The two projectors we have in a conference room periodically go to a blue screen and then come back up after a while.I can't simulate the problem when I try, but the users of this room complain that it is getting worse. Is this an inherrent problem with these projectors or are the two that I have just lemons? Could it be a problem with the code in the AMX control system?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
727
Points
Are they hooked up to a laptop? we've had the same problem with that before. When hooked up to the laptop it goes to sleep or turns off. bringing up the blue screen. maybe change the settings in the computer.
Why the projector automatically turns off after certian period say about 2 hours?
Does it turn off with a computer/video signal going to the projector? If it's just a blue screen, there's a timer within the projector that can be disabled. If there's a signal present, make sure the projector has good ventilation. If you're located in a high elevation, there's an option within the user menu to select "high elevation", which makes the RPM of the internal fans spin faster for better internal ventilation.
Macbook screen crashes when connected to projector
this is probably a projector setting
try checking the setting of both systems
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
1helpful
Blue screen appearing
not matching resolution. reset the settings to factory default. if it still has the problem, then swap cables. there may be a short or a break in the cable or connector.
Bouncing small lines on screen durning a spreadsheet presentation. This happens in our conference room during video transmission.
the resolution doesn't match. go into the menu and reset the settings to factory default, then re-select the computer and it should sync.
Blue cloud in the middle of our Hitachi 62VS69A Screen. Lamp went out and after replacing it we now have a blue cloud in the middle of our screen. Is it a bad lamp or could it be more than that?
if it is an lcd projector, its possible the lamp blew due to fan failure and the lamp getting hot prior to failure may have been enough to burn the lcd's. If it is an lcd projector, that's most likely what has happened
Blue Screen
You may have inadvertently switched your projector to a different input mode, or the mhz refresh rate, etc., Jon.
Sharp XGP25X Projector has large blue smudge on Screen
This is one of two things. Most likely there is a piece of dust or other obstruction right on top of the blue panel. I'm guessing that your smudge is in the lower center of the screen - that is where these usually occur. The other possibility is that the blue LCD panel is starting to deteriorate and the components separating. This is extremely expensive to repair and Sharp will end up giving you an estimate that approaches the replacement cost for a comparable new projector.
2answers
Projector Problems
There is some problem in your LCD Panels. Service the optical unit ant retry.
regards
Viren
Mp610 blue/black screen
Hi there
If the problem occurs again , you will most probably have to replace the mainboard , as all the inputs of the unit lies on the mainboard itself.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
