Question about Dryers
Change globe on heller trinity ceiling fan with oyster light
Change light bulb
Crossedwires
  • 44 Answers
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
patrick_a_t_
  • 3 Answers
SOURCE: Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
Posted on May 17, 2009
SOURCE: Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
Posted on Jun 10, 2009
How do I replace the light bulb on ceiling fan for Airworks. Can't twist it off!!!
Try putting on rubber gloves and turn the globe clockwise. The globe has a very smooth surface and is impossible to turn with bare hands because you cant get a grip on it.
You can read the whole forum below:
Replacing Ceiling Fan light bulb PhD required
Nov 16, 2016 | Dryers
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
How do I remove the light from the ceiling?
Sent you a question on this but did not receive a reply.
If you are talking about removing the grill/globe to change bulbs, it just pulls down from the ceiling. There is a heavy "V" spring on each side that needs to be compressed to pull the grill/globe down. Once it is down as far as it will go, the springs need to be squeezed together and the ends removed from the metal box in order to take the grill/globe off. It is not necessary to remove the grill/screen completely to change bulbs.
Please see my other message.
Paul
Sep 18, 2010 | Broan-NuTone N-8663RP Combination Light...
How do you change the light bulb
Remove the glass globe exposing the bulbs and replace. Some of the globes have screws around the metal rim that hold them in place and some actually unscrew as a unit.
Aug 28, 2010 | Hampton Bay 40093 Tripolie Ceiling Fan
How to change a light bulb
At the top of the globe there will be three small screws. Turn them counterclockwise out while holding onto theglobe so that it does not drop. Turn each screw just a few turns unitl the globe slides down and out. Replace the light bulb and then reverse the procedure to replace the globe...
Heatman101
Feb 24, 2010 | Hampton Bay 04345 Cruiser Ceiling Fan
My hampton bay ceiling fan it a rounded light and I don't know how to get to the light bulb to change it?
ther are three small screws that need to be loosen, once these are loose, the globe will come off and you can now change the light bulbs
Oct 18, 2009 | Madison Avenue 04889 Hampton Bay Ceiling...
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
23 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
